My zuk is sitting pissed
My zuk is sitting pissed after ive put a jack up kit on its a spring under axle on iron man leafs and ideas to why its sitting pissed?????
Re: My zuk is sitting pissed
did you do all the Ubolts up while it was jacked up on one side?
I always fit them loosly(ish) and then do them up fully when the sj is back on all 4 wheels.
Were they new springs you fitted or second hand?
did you put complete new springs on, or add-a-leaf? if add-a-leaf, your old springs could be knackered
- dazerede
I have the same problem aswell I have put a brand new set of standard springs on the rear and it is leaning to the right ( driverside) and there is a 2 inch gap diffrence in the arch gap
I will gets pics to show u
4” calmini lift kit
4” calmini lift kit
- waynesworld
dazerede wrote:I have the same problem aswell I have put a brand new set of standard springs on the rear and it is leaning to the right ( driverside) and there is a 2 inch gap diffrence in the arch gap
In your case you must be like minibreaker
- dazerede
Soz didn't get no pictures but I fitted a set of new springs on.the rear and then bolted everything up I might of done up the u bolts when the zook was still jacked up but I bolted them on and took it for a test run and everything looks about right but then I had to change the week bearing in.the rear axle so it was jacked like this for 2 days max and the zook is leaning to the drivers side and I just don't understand so once it has stopper raining I will take some photos and might just swap over the rear springs
- IMAG0250.jpg (1.7 MiB) Viewed 5389 times
4” calmini lift kit
4” calmini lift kit
