crap turning circle on.my 410
dazerede
Post by dazerede » Mon Dec 02, 2013 8:37 pm
Right I done a suzuki trial yesterday in.my anus and my turning circle is crap I just keep on driving into the canes when doing sharp corners the wheels do not catch the springs at all
O heard someone say you can cut a bolt down and this will improve it
4” calmini lift kit :)
Re: crap turning circle on.my 410
Post by Edweird » Mon Dec 02, 2013 9:54 pm
It could just be the terrain. My SJ was understeering in the mud at Wagtail
Post by Jordi » Mon Dec 02, 2013 10:37 pm
I blame bad driving. :hahaha:
Post by turbo-tom » Mon Dec 02, 2013 11:49 pm
Get pas on it makes light work of steering.
dazerede
Post by dazerede » Tue Dec 03, 2013 8:08 am
I have been told that there is a bolt that you can take out and this will help for sharp corners
Post by dan_2k_uk » Tue Dec 03, 2013 10:25 am
The full lock is normally limited by one of the bolts that hold the felt retaining plates on the knuckles. If you totally remove it the retainer will be less secure and the tyres will probably catch the springs.
Might be worth a little trim to get a little more from it though.
dndnk
Post by dndnk » Tue Dec 03, 2013 6:03 pm
Would wheel spacers make any difference ,tyres used to rub sprigs on my 410 before I fitted spacers
SJ 410 currently off road waiting to leap out of hibernation.
Please visit wifes web site http://www.apassionforcakes.co.uk/index.htm you might even find a zuke on there :-)
Post by Darrell » Tue Dec 03, 2013 8:13 pm
Found this post about the bolt.
I suppose it could be trimmed to the point where the tyre is almost touching the spring.
I assume the barfield joint won't mind a little extra angle ?
I don't think spacers will help as the steering angle would still be the same.
http://forum.suzukiclubuk.co.uk/vi ... ring+stops
Post by ScottieJ » Wed Dec 04, 2013 9:47 am
Wheel spacer increase the scrub radius so will actually reduce your turning circle compared to stock. It can also give more feedback from the road so it will be slightly harder to keep your SJ in a straight line and the steering will be heavier during turns.
