I'm Having A Nightmare
Scouse Lee
Post by Scouse Lee » Fri Dec 20, 2013 6:30 pm
Hey up guys, I've finally got round to making a start on putting my front axle back together after spending ages finding parts/waiting for them to come plus doing a thousand other things unrelated to the SJ.......anyway because I dismantled it a good while ago I'm having a bit trouble putting it back together, I've searched the internet from top to bottom for a walkthrough on rebuilding from the swivel seals to the freewheeling hubs but can't find one, ok I've found one for the hubs, one for the wheel bearings and a few other bits but nothing that takes you through the whole process. Of course I've got a Haynes manual but what an absolute waste of time that is, for instance it states that the torque specifications are in Ft-lbs (unless otherwise indicated) then says that the Front Wheel Bearing Nut is 96 to 132 in-lbs......so what is 96 in-lbs in Ft-lbs and why don't they just give it in Ft-lbs to begin with?
Scouse Lee
Re: I'm Having A Nightmare
Post by Scouse Lee » Fri Dec 20, 2013 6:35 pm
ok so I've googled convert in-lbs to foot-lbs and it says 96 in-lbs is 8 ft-lbs, does this sound right?
Ladaman
Post by Ladaman » Fri Dec 20, 2013 6:49 pm
Scouse Lee wrote:ok so I've googled convert in-lbs to foot-lbs and it says 96 in-lbs is 8 ft-lbs, does this sound right?
Spot on.
Imagine a 96 lbs weight one inch away from a pivot point on a bar.
To give the same torque at one foot away from that pivot you would only need 1/12 of that weight.
So 96 divided by 12 (inches in a foot for you youngsters) = 8 lbs
Scouse Lee
Post by Scouse Lee » Fri Dec 20, 2013 6:51 pm
Spot on.
Cheers Ladaman, why don't they just say 8 lbs then?, seems crazy to me..........any idea where I can find a complete axle rebuild walkthrough?
Post by ScottieJ » Fri Dec 20, 2013 7:14 pm
You can download a service manual in the 'general troubleshooting' section of the forum ;)
Ladaman
Post by Ladaman » Fri Dec 20, 2013 7:17 pm
No probs.
There is an exploded diagram here that may help.
http://forum.suzukiclubuk.co.uk/vi ... =12&t=2801
I have to pop out for a couple of hours now, but assuming Darrell (or someone else) hasn't posted something by the time I get back. I think I might have the Suzuki manual that I can probably put up for you. It's far better than the Haynes one.
Scouse Lee
Post by Scouse Lee » Fri Dec 20, 2013 7:20 pm
Thanks Scottie I did look in there before but I couldn't find what I was looking for, Ladaman that would be ace mate if you could......the Haynes one will be keeping me warm on xmas day when I put it on my fire ahaha
Scouse Lee
Post by Scouse Lee » Fri Dec 20, 2013 7:23 pm
on the plus side to all this mind is that last week I went to pick up a glove box door off a guy and ended up buying the whole SJ, (minus the engine, gear box & seats), ..........£150
Post by ScottieJ » Fri Dec 20, 2013 8:31 pm
Service manuals are Found in this thread.
http://forum.suzukiclubuk.co.uk/vi ... =16&t=2103
However one the links appears to be broken so I'll have to fix it on Monday.
Post by Darrell » Fri Dec 20, 2013 11:04 pm
I have added the section you need at the bottom.
Any more info needed , just ask :thumbup:
http://www.offroadingpics.co.uk/apps/documents/
