Famerbennie
Post
by Famerbennie » Mon Dec 30, 2013 6:06 pm
I Know This Has Been Done Millions & Millions Of Times But To Do A Jimny Power Steering Conversion On A SJ You Need
Jimny Box
Vitara Pump
Vitara Bottom Pulley
Vitara Belts
Vitara Res & Pipes
No Need For Any Other Pulleys etc
Does Anyone Have Pics/ Plans For Doing This
Don't Know If It Makes Any Difference But Mine Is A SJ410 With A 1300 Engine
Any Help Would Be Much Appreciated
Post
by Jordi » Mon Dec 30, 2013 6:25 pm
You can use the jimny reservoir and pipes but in my opinion neither the vit or jimny pipes fit very well. I had custom flexi pipes made.
Vitara pulleys are easiest but the bottom pulley needs re drilling to 4 stud instead of 5 stud. Not sure how easy it is to swap the alternator pulley over, or if a vit alternator will fit onto a 1.3?
Famerbennie
Post
by Famerbennie » Mon Dec 30, 2013 7:29 pm
Do You Have To Change The Alternator/ Pulley As I Saw Somewhere They Just Changed The Bottom Pulley
steve greenc3
Post
by steve greenc3 » Mon Dec 30, 2013 7:34 pm
I drilled vitara bottom pulley to four stud fixing, then changed water pump and alternator to vit pulley"s and run on flat belts.
Post
by donkeychomp » Mon Dec 30, 2013 11:12 pm
Just wondering why anyone wants power steering? I ran 31" tyres on my old SJ, never had any problems and I was using a 13" steering wheel too. Seems like more to go wrong and adding more weight.
Post
by Jordi » Mon Dec 30, 2013 11:14 pm
donkeychomp wrote:Just wondering why anyone wants power steering? I ran 31" tyres on my old SJ, never had any problems and I was using a 13" steering wheel too. Seems like more to go wrong and adding more weight.
I found it fine on 31/10.50 but slow maneuvering on the 33/12.50s was a lot harder. PAS is a god send on 33s and over.
Post
by turbo-tom » Mon Dec 30, 2013 11:15 pm
I use to run 31 on no pas and it was fine. i fitted pas because im lazy
Post
by dan_2k_uk » Mon Dec 30, 2013 11:18 pm
Yeah just a luxury really. The best luxury you could possibly think to add though!
Ladaman
- Suzuki Guru
Post
by Ladaman » Mon Dec 30, 2013 11:36 pm
dan_2k_uk wrote:Yeah just a luxury really. The best luxury you could possibly think to add though!
Agreed.
Rhino32pg
Post
by Rhino32pg » Wed Sep 01, 2021 12:17 pm
Famerbennie wrote: ↑Mon Dec 30, 2013 6:06 pm
Jimny Box
Vitara Pump
Vitara Belts
Vitara Res & Pipes
Hi Farmerbennie, Did you ever do this conversion on your SJ410 ?
