Mongolian Rally----Shell rebuild of destiny
gamble63
Post by gamble63 » Wed Dec 10, 2014 10:18 pm
So finally started to cut and begin to repair and modify the shell for our rally car.
As i was asking people about putting big tyres on and the best option was to do a virtual lift if i was repairing rot anyway, i started to cut parts away and it got worse and worse as you all know.
First had cut both sills out as they were shot only to find bodge after bodge:
that was the best bit of welding ive seen in a while.
Started cutting, and cutting, rear arches gone and inner arches gone as well as sills both gone.
made up new inner arches for the rear:
both need cutting down alot to the width of the tyres, but need welding first.
then had some sills made up and managed to fit one before i ran out of time, just needs trimming at each end and capping:
lots of work to do and im worried about the body mounts, they have rotted away and am wondering how to rebuild the ones behind the seats with sufficient strength.
Re: Mongolian Rally----Shell rebuild of destiny
Post by donkeychomp » Wed Dec 10, 2014 10:26 pm
Looking good :smokin:
Post by Anton » Wed Dec 10, 2014 10:56 pm
Very good work so far! :D
Post by Edweird » Wed Dec 10, 2014 11:57 pm
We shell rebuild!
gamble63
Post by gamble63 » Sun Dec 21, 2014 6:53 pm
Bit more progress moving closer to the front of the car slowly,
front body mounts taking alot longer than id like as bits keep falling off.
outter part has been done but now the inside skin and body mount need building.
Post by andyrew » Sun Dec 21, 2014 7:23 pm
Very neat and tidy.
Lovely welds
gamble63
Post by gamble63 » Sun Dec 21, 2014 8:06 pm
Thanks dude. Only annoying part is when you are welding clean plate to clean plate its nice and smooth and easy to weld, soon as you wanna weld clean plate onto old zook it starts having a hissy fit.
have started the other side but not happy with the bit i welded onto the sill so will be cutting that off as not done the same on the other side.
Post by ScottieJ » Sun Dec 21, 2014 9:48 pm
Awesome work and again that's some lovely welding! We all know that one! Sj bodywork can be a nightmare to weld.
gamble63
Post by gamble63 » Sun Dec 21, 2014 9:58 pm
cheers guys, im making it all up as i go along so hopefully will be all good.
quite enjoying it at the mo :)
cheers
Post by donkeychomp » Sun Dec 21, 2014 10:09 pm
weldporn...
