door cards
trisha
door cards
Post by trisha » Fri Sep 12, 2014 2:03 pm
can anyone help me, looking for two door cards for suksuki sj413 1986
cant seem to get anywhere. thanks
:salute:
Re: door cards
Post by dan_2k_uk » Sat Sep 13, 2014 3:21 pm
If its not a standard restored job just make some out of some thin aluminium sheet.
Re: door cards
Post by donkeychomp » Sat Sep 13, 2014 5:20 pm
And someone just binned a set...always the way
trisha
Re: door cards
Post by trisha » Sun Sep 14, 2014 10:27 am
i live in spain and the mot center wont test it, now it has to be too factory settings totally what a pain, i have just had to take all the aluminum treadplates from doors sills and bonnet also had to remove bullbar to get it tested, may have to custom make door cards out of plywood and spray matt grey, thanks anyway
Cyprus Geoff
Re: door cards
Post by Cyprus Geoff » Sat Jan 17, 2015 11:23 am
Bet they would test it if a local guy pitched up with it for MOT?
Re: door cards
Post by Anton » Sat Jan 17, 2015 11:51 am
Make them out of fibreboard or something like that, then cover them with vinyl fabric. If they look like they could be factory, then he should be ok with it. Otherwise, ring around the garages local to you, explain the situation (my truck is standard except for the stupid door cards) and maybe you'll find an MOT man who isn't so stupidly petty.
muddymesser
Re: door cards
Post by muddymesser » Sat Jan 17, 2015 8:22 pm
It's not to hard to make a set
