Cheers! Motivation is high with the cooling temperatures.dan_2k_uk wrote:Looking very nice. Keep it up.
Drew up my crossmember for lower links, gearbox and transfer. Clearanced for exhaust, front shaft and fuel/brake lines while giving a flat chassis. Hopefully the theory works out.
![Image](http://i1276.photobucket.com/albums/y466/danielfff/039C06F2-1D61-4804-81F7-04C5979B8901_zpsbuuiquij.jpg)
Random diff pic.
![Image](http://i1276.photobucket.com/albums/y466/danielfff/7B5D4C14-4823-4272-8348-0C14A2FF3725_zpsqa3efype.jpg)
As long as they're bigger than my 31's and no wider I'm happy, haha. The KM2 isn't likely to let me down, I can't wait to use them.Anton wrote:My old 31x10.5R15 BFG muds were about 29" even at 30psi. So I think you're doing well! My 31" Malatestas are roughly a true 31" at 20psi, and noticeably larger. My truck doesn't look like a rollerskate anymore!
I get the feeling that most BF tyres are a little undersized, my neighbour has a Hilux Surf on 33" BFG AT's, and they're roughly the same size as my Kaimans, only a lot lot wider.
