electric fuel pumps
electric fuel pumps
Hey dudes
I've got to purchase an electric pump to feed the weber
For the vit conversion. Can anyone recommend
A brand they've had good experience with?
Any too avoid?
Any too avoid?
Re: electric fuel pumps
I borrowed Scotties truck a few weekends ago. Dont use whatever he uses. Too loud.
It is solid mounted and right behind the driver seat in the back that doesn't help! Need to get some isolated rubber mounts for it, that will quieten it down.dan_2k_uk wrote:I borrowed Scotties truck a few weekends ago. Dont use whatever he uses. Too loud.
This is what i use to feed vitara carb, it works great. You don't even hear it. I have it mounted in engine bay.
http://www.kraftstoffpumpen.com/benzinp ... -c-25.html
- kibris
I use one of these
Click Here for Ebay Listing
designed to suck so can be mounted under bonnet - works well - lot quieter than the facet.
I've got a facet pump Andy. Now mounted on a rubber bush.
im guesing the fuel return just gets blanked off?
There won't be a fuel return. The webber doesn't have one, just fuel in. The fuel return is off the pump on the propper carb'd 1.3 and 1.6s.andyrew wrote:im guesing the fuel return just gets blanked off?
Ive got one of the black plastic facet pumps and haven't had any problems with it...
Its really loud clicking when it runs out of fuel!
I bought a generic thing from my local factors. It makes a horrible noise because it's hard mounted to the inside of the chassis just forward of the tank - I really need to mount it using rubber mounts (ala t-case mounts) instead.
