Marooned
Catweezil
Marooned
Post by Catweezil » Sun Apr 12, 2015 12:36 pm
Chaps
Went to go and see my bee's today in the Suzuki GV 2000ltr '02 reg and it wouldn't start so I tried jumping it with the Mrs car no joy. It did sound like a flat battery.
Bought a new batt from halfords just fitted it and it still wont start. :S :shock:
Have you any advice you could impart? Really need the fella up and running ASAP.
Re: Marooned
Post by ScottieJ » Sun Apr 12, 2015 3:32 pm
Is the starter not even turning the engine over?
d_r_1989
Re: Marooned
Post by d_r_1989 » Sun Apr 12, 2015 3:43 pm
With the new battery does it still sound like a flat battery? If you tow the car down the road is it still the same?
Catweezil
Re: Marooned
Post by Catweezil » Sun Apr 12, 2015 4:31 pm
ScottieJ wrote:Is the starter not even turning the engine over?
No
Catweezil
Re: Marooned
Post by Catweezil » Sun Apr 12, 2015 4:33 pm
d_r_1989 wrote:With the new battery does it still sound like a flat battery? If you tow the car down the road is it still the same?
Only have a focus with the Mrs init and so its probably best we don't go there, towing that is. :smokin:
Re: Marooned
Post by Anton » Sun Apr 12, 2015 4:35 pm
Could be a dodgy starter motor or solenoid. Does it click when you turn the key?
Catweezil
Re: Marooned
Post by Catweezil » Sun Apr 12, 2015 4:37 pm
Can anyone recommend a good mechanic in this Parish of Nth Wilts? round J17 M4? Will travel if he/she comes highly recommended. Will have to bump it or tow it then
Catweezil
Re: Marooned
Post by Catweezil » Sun Apr 12, 2015 4:39 pm
Anton wrote:Could be a dodgy starter motor or solenoid. Does it click when you turn the key?
Not really just tries to turn over but cant. I think I did hear a low volume clicking at one point. Will go outside and try it again to see.
Catweezil
Re: Marooned
Post by Catweezil » Sun Apr 12, 2015 4:41 pm
It just clicks the once and tries to turnover.
d_r_1989
Re: Marooned
Post by d_r_1989 » Sun Apr 12, 2015 4:53 pm
I mention towing so you can eliminate the Starter from the equation. You could push it to bump start it providing it has enough power in battery to let the ecu control the spark when first firing.
IT sounds like a starter fault to be honest, try hitting the starter with something heavy just in case the solenoid is stuck or rock it back and forth in say 4th gear then try start it, obviously when it's back in neutral!
I'm pretty sure if it was the immobiliser it would turn over as normal but just not fire.
Worst case scenario is seized engine but that doesn't happen overnight!
