Grand Vitara 2004.
Current in my front bumper there are no fog / spot lights.
Is there a loom which is mounted in the engine bay where once I fit the lights can then be connected or
Do you need to start from scratch and install it all.
Thanks.
Adding front fog / spot lights
Grand Vitara,54 plate,2000cc,Manual,5 Door,Air Con,4WD.
Re: Adding front fog / spot lights
Sorry not really noticed if there are any models that had fogs, but if yes there is a possibility that could be wiring down there
You need to check the wiring is in place. If so you just need the lights,switch and probably a relay/fuse installed in the appropriate sockets.
- GV SQ 2003-2005 front fog.png (81.87 KiB) Viewed 4580 times
