HELP i need a starter
lightning
Post by lightning » Thu Mar 03, 2011 3:23 pm
I got 1 from Wood Auto as you suggested This is the starter I originally started off with.
These a Peugeot/Citroen starters and are ONLY £56 BRAND NEW
Get them new from here: http://www.woodauto.com/Unit.aspx?Man=VALEO&Ref=D6RA12" onclick="window.open(this.href);return false;
Note: I just phoned up Wood Auto to confirm they have them... they currently have 55 in stock, and they are still in production, apparently they will have a supply of them for some time
It looks very similar to the D6RA62, but can be told apart from it due to the different size housing although the motor itself and the solenoid are the same.
This starter had 9 teeth and will fit on a Suzuki.
IT WILL NOT FIT :argh:
i have done the 1.6 conversion with 1.3 gear box
Need help at my wits end :bawling: :bawling:
Mark
Re: HELP i need a starter
Post by ScottieJ » Thu Mar 03, 2011 4:08 pm
I'm sure Twiss will be on to help soon, he's the one with the info on these alternative starters :thumbup:
What model starter have you got? also have you still got the original starter?
lightning
Post by lightning » Thu Mar 03, 2011 4:41 pm
ScottieJ wrote:I'm sure Twiss will be on to help soon, he's the one with the info on these alternative starters :thumbup:
Got the 1 out of the 1.6 but that dose not fit, hits the engine
Tryed the original starter out the old engine (410) that dose not fit.
Post by ScottieJ » Thu Mar 03, 2011 5:00 pm
what model of starter di you buy from wood auto?
ferris
Post by ferris » Thu Mar 03, 2011 5:48 pm
With a small amount of grinding on the engine and the starter, you should be able to fit your fat starter on there. I know its not ideal but desperate times call for desperate measuers :twisted:
lightning
Post by lightning » Fri Mar 04, 2011 8:15 am
ferris wrote:With a small amount of grinding on the engine and the starter, you should be able to fit your fat starter on there. I know its not ideal but desperate times call for desperate measuers :twisted:
I dont fancy grinding the engine :shock:
lightning
Post by lightning » Fri Mar 04, 2011 8:23 am
ScottieJ wrote:what model of starter di you buy from wood auto?
The 1 in Twiss link Valeo D6RA12 or wood auto part No STR54021
Post by ROBBIE » Fri Mar 04, 2011 10:03 am
ive ground two engines now no problem, just go easy
lightning
Post by lightning » Fri Mar 04, 2011 11:20 am
Fancy doing mine :brows:
ferris
Post by ferris » Fri Mar 04, 2011 5:30 pm
If its any help the part number on my skinny starter is M1T74583 and that measuers 3inches in diameter.
