Yes m8ROBBIE wrote:is the engine in?
HELP i need a starter
Re: HELP i need a starter
dont think it can be ground down, dont think we could get the grinder in
have you tried difflock adds?
just looked in the diff ads and theres nothing there ecept for people looking for starters
I'm gonna pull my starter off and see double check it's exactly the same as the one in my shed...
All of the bits off the valeo starters are interchangeable...
So if you grind/drill the rivets off, you can just bolt it straight together
Thanks for your helptwiss wrote:I'm gonna pull my starter off and see double check it's exactly the same as the one in my shed...
Will the starter that ferris part No M1T74583 fit 100% with out no grinding?dont want to get the wrong one again
just need a starter
dont know if its the 1 you want http://cgi.ebay.co.uk/suzuki-sj-starter ... 2c5b0be29c" onclick="window.open(this.href);return false;
I dont wan't to be responsable for you getting the wrong starter again. Heres a bit more info that might help. That part number is off the skinny starter im am using on my sj. I didn't buy it from new, i bought it from another member on here (parrot). He bought it from new, here is his post from difflock when he got it http://forum.difflock.com/viewtopic.php ... 78686098b1" onclick="window.open(this.href);return false;. If you did decide to order this one it might be best to get them to measure it for you befor they send it. The diameter of the skinny ones are 3" and the fat ones are 3 1/4". Hope this helps in some way, and good luck with the search. I know i had a nightmare trying to get hold of mine.
Also here is a couple of pictures of mine. Sorry the part number is a bit blurry in the pic.
Just measured my old fat starter and it measures 3 1/4" not 4" like i said previously i just edited the above post to correct myself.
So just to confirm skinny starter 3"
Fat starter 3 1/4"
So only 1/4" differance between the 2.
Fat starter 3 1/4"
Thanks for your help that looks like the one i wantferris wrote:Just measured my old fat starter and it measures 3 1/4" not 4" like i said previously i just edited the above post to correct myself.
Fat starter 3 1/4"
Just so you know, there is someone on difflock who has a skinny starter and might not need it (philpy)
Check out this thread on difflock
http://forum.difflock.com/viewtopic.php?t=61412" onclick="window.open(this.href);return false;
