Air filter
Rjmaas512
Air filter
Post by Rjmaas512 » Sun Jul 31, 2011 3:36 pm
My SJ currently has no air filter. Have an air box now and pipe, however no elbow to sit on top of the carb.
I am after something looking like this:
http://t1.gstatic.com/images?q=tbn:ANd9 ... B-ryNssBgs" onclick="window.open(this.href);return false;
Picture of my carb uploaded. Any ideas on what to use to connect the air box to the carb? I have searched ebay with nor much success so need some help here.
Thanks,
Rob
Rjmaas512
Re: Air filter
Post by Rjmaas512 » Sun Jul 31, 2011 8:47 pm
Picture uploaded
Engine Top (Small).JPG (86.24 KiB) Viewed 8116 times
Re: Air filter
Post by twiss » Mon Aug 01, 2011 10:26 am
It's called the plenum chamber. I may have a spare one in my shed... I'll let u know if I find one!
Rjmaas512
Re: Air filter
Post by Rjmaas512 » Mon Aug 01, 2011 6:01 pm
twiss wrote:It's called the plenum chamber. I may have a spare one in my shed... I'll let u know if I find one!
Ah, ha that's what they're called. Spent ages trying to find out what its called.
If you have one it would be amazing :thumbup:, having so much trouble finding one, and its the final thing I need to have an air filter :)
Re: Air filter
Post by twiss » Tue Aug 02, 2011 10:13 am
Air filter you should be able to get from any motor spares shop... I would put a K&N style one on it though :)
Rjmaas512
Re: Air filter
Post by Rjmaas512 » Tue Aug 02, 2011 10:47 am
Got the air box and hoses + air filter, just need the plenum chamber to connect the air box to the carb
Rjmaas512
Re: Air filter
Post by Rjmaas512 » Thu Aug 04, 2011 10:52 pm
Did you manage to have a look in your shed to see if you had that part? I am able to go past a breakers tomorrow, so just wondering what parts to collect
Re: Air filter
Post by twiss » Fri Aug 05, 2011 9:34 am
Sorry chap I haven't had a chance to have a proper look. My shed is a mountain of suzuki parts and other bits and pieces at the minute...
Rjmaas512
Re: Air filter
Post by Rjmaas512 » Wed Aug 10, 2011 11:20 pm
Well I have a carb elbow. £25.00 for a piece of metal!
will stick it on the carb with some TRV sealant and a bolt, then cut up and modify my bonnet.
The bonnet doesn't close by a few inches!
Re: Air filter
Post by twiss » Thu Aug 11, 2011 9:36 am
Ahhhh excellent! It may be worth checking how many spacers there are inbetween the carb and the manifold. If there's enough room to take the spacer out and the levers still work then you can drop the height by about 1 cm...
