Pipe bending?
Newtomud
Pipe bending?
Post by Newtomud » Sat Sep 24, 2011 6:33 pm
Is this sort of thing any good?
http://www.ebay.co.uk/itm/BRAND-NEW-16- ... 9010844390" onclick="window.open(this.href);return false;
dunk
Recommended Trader
Recommended Trader
Re: Pipe bending?
Post by dunk » Sat Sep 24, 2011 6:41 pm
They work well but it depends on what you are trying to make with it and how fussy you are. I am very fussy, that's why I was happy i got to use a jd2 bender when my cage was bent. The bends are so nice and even. This type of bender does crush tube when you bend it. I have built a few cages using a very similar bender. You may find them cheaper at machine mart
sam16v
Re: Pipe bending?
Post by sam16v » Sat Sep 24, 2011 8:00 pm
I have one of these benders, theyre not bad. if you want to bend big stuff like cages etc then you need to pack the tubes with sand, gaffa tape the ends up then bend, other thing i found was that the formers work better if you clean the castings up so that they actuallty fit the tubing better. hope this helps
Re: Pipe bending?
Post by ROBBIE » Sun Sep 25, 2011 1:23 pm
how about this
dominic
Re: Pipe bending?
Post by dominic » Wed Sep 28, 2011 10:04 pm
Nice one Robbie,
Futurama's Bender is class. :robot:
Dom
:smokin:
Currently Drive
SJ 410 Q 1985 (GREEN)
VITARA GL+ 2017 (SILVER)
Henry
Re: Pipe bending?
Post by Henry » Thu Sep 29, 2011 9:34 am
Im using one on my cage. Had to put a sleeve in on of there former so it was tight around the steel tho!
Newtomud
Re: Pipe bending?
Post by Newtomud » Tue Oct 25, 2011 9:55 am
dunk wrote:They work well but it depends on what you are trying to make with it and how fussy you are. I am very fussy, that's why I was happy i got to use a jd2 bender when my cage was bent. The bends are so nice and even. This type of bender does crush tube when you bend it. I have built a few cages using a very similar bender. You may find them cheaper at machine mart
I found some pics on a post (Newby alert-Oct 2010) That's a very nice cage :thumbup:
Ladaman
Re: Pipe bending?
Post by Ladaman » Mon Oct 31, 2011 11:47 pm
I'd get one of these.
How cool? :smokin:
Click Here for Youtube Video
Newtomud
Re: Pipe bending?
Post by Newtomud » Tue Nov 01, 2011 8:36 am
Ladaman wrote:I'd get one of these.
How cool? :smokin:
That is a stunning tool and so quick too.Might be out of my price range.
vitara_mad
Re: Pipe bending?
Post by vitara_mad » Fri Nov 11, 2011 11:07 am
How cool? :smokin:
if i start saving now i might just be able to afford one in about 2511 :thumbdown:
