Now lifted before & after
1991 Samurai
Rough Country Lift/Shocks
Cherry Bomb Exhaust
Bronco Diamond Back 215/15
Llama Brake Hose
Cherry Bomb Exhaust
Llama Brake Hose
Re: Now lifted before & after
Hi, that's a very white SJ!!!
How did you lift it up? Lift springs or add a leaf?
The front looks quite a bit lower than the back... maybe worth knocking up some slightly extended shackles so its the same height?
Up to you though!
Up to you though!
Looks good, now just needs some bigger boots
Looks good kinda like everything white!, bet it's fun to look for in the snow
matt...
matt...
Add a Leafs it look more than 2" to me though, the clearance from the ground to sill is over 20". Need rear shocks first then will get new rubber.twiss wrote:Hi, that's a very white SJ!!!
Up to you though!
1991 Samurai
Cherry Bomb Exhaust
Llama Brake Hose
Cherry Bomb Exhaust
Llama Brake Hose
