winch
adamsj
winch
Post by adamsj » Thu Mar 08, 2012 10:27 pm
is a 4000lb winch enough for an sj.its about 1800kg i think
Highlander
Re: winch
Post by Highlander » Fri Mar 09, 2012 9:44 am
No, it would pull it up an incline or onto a trailer ok but if you need to get up a steep hill or get badly bogged down in mud its not going to do the job.
The lowest rating winch I have on an SJ is 8000lb although I've pulled out 2.5t bogged Landrover's with that
I've seen 6000lb winches on the rear of Sj's that seem to do a good job but I think going any lower than that would find you kicking yourself first time you get really stuck :D
If you go with a lower capacity winch then adding a snatch block for a double line pull will make a huge difference, they basically double your pulling capacity (and half the speed)
adamsj
Re: winch
Post by adamsj » Fri Mar 09, 2012 12:07 pm
cheers mate
adamsj
Re: winch
Post by adamsj » Fri Mar 09, 2012 12:21 pm
so if i bought a 4000lb winch and used a snatch block that would be ok?
Highlander
Re: winch
Post by Highlander » Fri Mar 09, 2012 12:33 pm
It all depends on what you aim to use it for
but for offroading I'd say no, its not powerful enough to get a well stuck Suzuki out.
An 1800Kg winch is at the top of end of what the big quad bikes use.
I've been offroading probably 25 years now and never seen anything under a 4000lb winch on a Suzuki
ianedwards
Re: winch
Post by ianedwards » Fri Mar 09, 2012 12:42 pm
Hi,
ive been looking at the champian 9500lb short drum with synthetic rope, for the front of my sj.
ive heard good things about it, wheighs sod all and would be ideal me thinks,
bit pricey but looks quite good.
Ian
Ian. :)
adamsj
Re: winch
Post by adamsj » Fri Mar 09, 2012 12:48 pm
okie dokie
Highlander
Re: winch
Post by Highlander » Fri Mar 09, 2012 1:05 pm
I've got two Champion winches on Suzuki's Ian, had them for ages and they work very well.
Highlander
Re: winch
Post by Highlander » Fri Mar 09, 2012 1:16 pm
This lot are doing a Champion 6000 for £198
I think thats a good buy, the 8000 is £310
http://www.firstfour.co.uk/item/2165733/champion-c6000s
8000 on ebay for £246 :doublethumbs:
http://www.ebay.co.uk/itm/Champion-C800 ... 1225wt_907
sus
Re: winch
Post by sus » Sun Mar 18, 2012 4:15 pm
ianedwards wrote:Hi,
Ian
i have exact winch on my vit, and its a fab win :thumbup: ch
