Body mount positions
Post by ScottieJ » Fri Feb 25, 2011 12:30 pm
boddy mounts.JPG (221.72 KiB) Viewed 81337 times
Jay18
Re: Body mount positions
Post by Jay18 » Fri Apr 06, 2012 2:56 pm
this is great help, thanks mate!
2003 Grand Vitara 2.0 16v
16x7 Black 8 spokes
Nexen road tyres
32mm spacers
Kenwood Double Din Head Unit
Hidden CB radio
Cruise Control
GV Build Thread
SJ Build Thread
Facebook
SuzukiPicsUK on Instagram
LDM
Post by LDM » Wed Aug 23, 2017 4:07 pm
Are the body mount fixings on a SJ, studs fixed to the body / chassis or bolts that can be replaced if the rubber mounts are replaced?
I am about to start a body of restoration and am suspecting the bolts/studs will shear when I try to undo them
Post by ScottieJ » Wed Aug 23, 2017 4:20 pm
The 2 at the front and 2 at the rear are bolts with captive nuts on the chassis so they can be replaced.
The 6 in the middle are studs fixed in the body but the nuts always come off fine, I've never had one break or strip the thread.
The rear 2 bolts normally come out fine, the fronts do sometimes shear but if you give them a good spray with wd40/penetrating oil a few times over a few days before trying to get them out they should come out fine, you can get to the threads underneath to clean them up before trying to remove them as well, that helps.
I've had a lot of sj bodies off and the fronts are the only ones that sometimes give you some trouble.
LDM
Post by LDM » Wed Aug 23, 2017 4:52 pm
Thanks for the reply, I will give everything a good spray of WD40 over the next few weeks - before I tackle the body removal.
Any suggestions / thoughts on replacement rubber / mounts suppliers? I am keeping it standard (no body lift) but am not sure whether OE or some modern material is better.
Cheers.
Post by ScottieJ » Wed Aug 23, 2017 5:13 pm
http://www.ebay.co.uk/itm/BRAND-NEW-SUZ ... SwCWFY8Iwz
I've just used one of these kits from india.
LDM
Post by LDM » Wed Aug 23, 2017 5:17 pm
I guess that's a vote for standard - Cheers
LDM
Post by LDM » Wed Aug 23, 2017 9:30 pm
Will order some from ebay.
ARCDEB
Post by ARCDEB » Thu Apr 03, 2025 6:08 pm
Hi peeps can anybody please tell me the side of the body to chassis bolts and nuts for a 1983 SJ410 i think they are metric fine but i am nut sure of the size. Thanks in advance Alan
Post by ScottieJ » Fri Apr 04, 2025 10:24 am
M10x1.25
Suzuki use JIS for fasteners
(Also I’ll fix the image in the first post later)
