rev counter is not working now its gone up the swaney!!!
- turbo-tom
rev counter is not working - dont think its not connected but i have the 8v vit lump , and were do/ is it meant to be connected up to ?
thanks tom
thanks tom
Tom
Ford Fiesta ST
Ford Fiesta ST
Re: rev counter is not working
Normally goes to the coil negative terminal. I would give that a try.
- 413 Coil Wiring.jpg (60.64 KiB) Viewed 7709 times
- turbo-tom
cheers mate for that , just tried it and no luck
, just going to by a universal one i think now
thanks anyway
thanks anyway
Tom
Ford Fiesta ST
Ford Fiesta ST
- turbo-tom
Re: rev counter is not working now its gone up the swaney!!!
tried that again but nope still wont work
going to by one of thesee
Click Here for Ebay Listing
emailed the seller he said it "should work" on my coil
so its universal brand new, so your opinions please
- will it wokr.jpg (83.04 KiB) Viewed 7600 times
Tom
Ford Fiesta ST
Ford Fiesta ST
- Edweird
Well, it looks like it works the same way the one I've designed does. Takes the LT frequency as an input. As he said, it should work provided there's no gremlins in the system.
- turbo-tom
cheers ed so you say this one would be okay?
Tom
Ford Fiesta ST
Ford Fiesta ST
- Edweird
I think so. It takes it's input from the same place as mine, and mine works.
More info.............
- rev1.jpg (29.24 KiB) Viewed 7521 times
- rev2.jpg (55.61 KiB) Viewed 7521 times
- turbo-tom
im not that good at diagrams pal!
ive got the brown and white wire comming out of the original loom and thats it and its been cut off ? tried putting into the coil were suggest and got nothing...
does it have to go through a noise supressor or something ?
Tom
Ford Fiesta ST
Ford Fiesta ST
- Edweird
That would probably depend on the one you've bought as to whether it need to go through the suppressor. Given your old one stopped working the suppressor is one of the things that could have broken though.
