does anyone have a wiring diagram for the ignition coil?
Jay18
Post by Jay18 » Fri Sep 14, 2012 11:07 am
i am fitting an electronic ignition and need to know what wires do what, so if anyone can tell me by the colour of the wires or a wiring diagram it would be a great help!
thanks in advance...
2003 Grand Vitara 2.0 16v
16x7 Black 8 spokes
Nexen road tyres
32mm spacers
Kenwood Double Din Head Unit
Hidden CB radio
Cruise Control
GV Build Thread
SJ Build Thread
Facebook
SuzukiPicsUK on Instagram
Re: does anyone have a wiring diagram for the ignition coil?
Post by Darrell » Fri Sep 14, 2012 11:30 am
This do ya -
413 Coil Wiring.jpg (60.64 KiB) Viewed 31163 times
413 Ignition circuit.jpg (20.18 KiB) Viewed 31163 times
Post by Darrell » Fri Sep 14, 2012 11:39 am
I assume you have the correct coil for electronic ignition as well :thumbup:
Jay18
Post by Jay18 » Fri Sep 14, 2012 7:56 pm
i knew i could count on you having a diagram! lol and i need a new coil? i have bought a blacktop universal electronic ignition that wires into the original wiring which is why i needed the diagram...
and i have a sj410 is the coil wiring the same as the 413?
16x7 Black 8 spokes
Nexen road tyres
32mm spacers
Hidden CB radio
Cruise Control
GV Build Thread
SJ Build Thread
Facebook
Post by Darrell » Fri Sep 14, 2012 8:05 pm
The 410 coil has a ballast resistor fixed to the side. This limits the voltage to the coil to about 9v I believe. This ballast resistor is by-passed under starting only. If it was fed 12v all the time I would expect it to overheat.
Any more info about the kit you have brought.
Diagram as shown in workshop manual (I haven't seen one with my own eyes :D )
I would assume that it would have either black/yellow to solenoid or black/green to starter. Not both as they both do the same job of supplying 12v on start-up.
410 Ignition circuit.jpg (24.46 KiB) Viewed 31144 times
Post by Darrell » Fri Sep 14, 2012 8:16 pm
I would expect your kit to just replace the points so I doubt if you need to change the coil, I only suggested this as I assumed you had a 413 dizzy to fit :oops: .
Jay18
Post by Jay18 » Fri Sep 14, 2012 8:17 pm
its in the gloveox at the moment with the instructions lol but this is the one..
Click Here for Ebay Listing
16x7 Black 8 spokes
Nexen road tyres
32mm spacers
Hidden CB radio
Cruise Control
GV Build Thread
SJ Build Thread
Facebook
Post by Darrell » Fri Sep 14, 2012 8:42 pm
I think your need to fish out the diagram that came with it. A little strange as it still uses the points, but I assume it takes the current off them which will make them last much longer and therefore keep your timing correct for longer.
I always thought electronic ignition was to do away with the points :er:
Post by Darrell » Fri Sep 14, 2012 9:18 pm
Had a look on fleabay and it says the 4 wires are power,earth,coil & contact breaker, so it's like this ??
410 ignition with electricory.jpg (45.18 KiB) Viewed 31131 times
Jay18
Post by Jay18 » Fri Sep 14, 2012 11:12 pm
thanks mate! thats saved me alot of thinking lol will get that done soon also have to change the points as ive got a new set so need to get myself a timing light..
get that done, bit of underseal here and there, paint front bumper and off the ATS for the MOT starting to get a bit excited now lol...
16x7 Black 8 spokes
Nexen road tyres
32mm spacers
Hidden CB radio
Cruise Control
GV Build Thread
SJ Build Thread
Facebook
