does anyone have a wiring diagram for the ignition coil?
i am fitting an electronic ignition and need to know what wires do what, so if anyone can tell me by the colour of the wires or a wiring diagram it would be a great help!
thanks in advance...
2003 Grand Vitara 2.0 16v
16x7 Black 8 spokes
Nexen road tyres
32mm spacers
Kenwood Double Din Head Unit
Hidden CB radio
Cruise Control
GV Build Thread
SJ Build Thread
Facebook
SuzukiPicsUK on Instagram
16x7 Black 8 spokes
Nexen road tyres
32mm spacers
Hidden CB radio
Cruise Control
GV Build Thread
SJ Build Thread
Re: does anyone have a wiring diagram for the ignition coil?
This do ya -
- 413 Coil Wiring.jpg (60.64 KiB) Viewed 31158 times
- 413 Ignition circuit.jpg (20.18 KiB) Viewed 31158 times
I assume you have the correct coil for electronic ignition as well
i knew i could count on you having a diagram! lol and i need a new coil? i have bought a blacktop universal electronic ignition that wires into the original wiring which is why i needed the diagram...
and i have a sj410 is the coil wiring the same as the 413?
16x7 Black 8 spokes
Nexen road tyres
32mm spacers
Hidden CB radio
Cruise Control
GV Build Thread
SJ Build Thread
Facebook
16x7 Black 8 spokes
Nexen road tyres
32mm spacers
Hidden CB radio
Cruise Control
GV Build Thread
SJ Build Thread
The 410 coil has a ballast resistor fixed to the side. This limits the voltage to the coil to about 9v I believe. This ballast resistor is by-passed under starting only. If it was fed 12v all the time I would expect it to overheat.
Any more info about the kit you have brought.
Diagram as shown in workshop manual (I haven't seen one with my own eyes
I would assume that it would have either black/yellow to solenoid or black/green to starter. Not both as they both do the same job of supplying 12v on start-up.
- 410 Ignition circuit.jpg (24.46 KiB) Viewed 31139 times
I would expect your kit to just replace the points so I doubt if you need to change the coil, I only suggested this as I assumed you had a 413 dizzy to fit
its in the gloveox at the moment with the instructions lol but this is the one..
Click Here for Ebay Listing
16x7 Black 8 spokes
Nexen road tyres
32mm spacers
Hidden CB radio
Cruise Control
GV Build Thread
SJ Build Thread
Facebook
16x7 Black 8 spokes
Nexen road tyres
32mm spacers
Hidden CB radio
Cruise Control
GV Build Thread
SJ Build Thread
I think your need to fish out the diagram that came with it. A little strange as it still uses the points, but I assume it takes the current off them which will make them last much longer and therefore keep your timing correct for longer.
I always thought electronic ignition was to do away with the points
Had a look on fleabay and it says the 4 wires are power,earth,coil & contact breaker, so it's like this ??
- 410 ignition with electricory.jpg (45.18 KiB) Viewed 31126 times
thanks mate! thats saved me alot of thinking lol will get that done soon also have to change the points as ive got a new set so need to get myself a timing light..
get that done, bit of underseal here and there, paint front bumper and off the ATS for the MOT starting to get a bit excited now lol...
16x7 Black 8 spokes
Nexen road tyres
32mm spacers
Hidden CB radio
Cruise Control
GV Build Thread
SJ Build Thread
Facebook
16x7 Black 8 spokes
Nexen road tyres
32mm spacers
Hidden CB radio
Cruise Control
GV Build Thread
SJ Build Thread
