LJ80 TAIL SHAFT PCD??
pro4x4@hotmail.com
Post by pro4x4@hotmail.com » Fri Nov 02, 2012 8:29 pm
Hi Guys,
Any one know if the PCD is the same for LJ and SJ Tail shafts??
Chris..
Re: LJ80 TAIL SHAFT PCD??
Post by ScottieJ » Fri Nov 02, 2012 8:52 pm
I'm pretty sure it is. I have stacks of spare lj80 prop shafts if you need one.
pro4x4@hotmail.com
Post by pro4x4@hotmail.com » Fri Nov 02, 2012 9:21 pm
Cheers Scott.. I moved my front diff foward so need a spacer or longer shaft..
Post by Tramp » Fri Nov 02, 2012 10:55 pm
I think bits4vits do a spacer with a multitude of holes, I'm not 100% sure but I think this spacer fits the skinny prop SJ so should fit an LJ too, I'd check your pcd is right before ordering though!
http://www.bits4vits.co.uk/store/vitara ... od_27.html
If you browse the site they do different thickness spacers too
Post by Darrell » Fri Nov 02, 2012 11:55 pm
Questions have popped up quite a few times regarding propshafts and I don't know of a useful list of measurements. So I've done a diagram (there's a surprise) and hopefully you guys with spares can get a few measurements for future reference.
prop diagram.jpg (69.23 KiB) Viewed 10978 times
The pcd can be worked out as length C divided by 0.707
My D reg SJ413 ,The only info I have is
A= 8mm
C= 56mm
PCD= 79.2mm
Universal joint size =
Well it's a start :oops:
Post by Darrell » Fri Nov 02, 2012 11:58 pm
Scott, feel free to copy this to a new thread if you think it's worth the bother :thumbup:
Cheers.
Post by Darrell » Sun Nov 04, 2012 8:44 pm
Well I've been searching the tinternet and found absolutely sod all info :thumbdown:
We can add to it in time I guess :popcorn:
prop info.png (30.24 KiB) Viewed 10930 times
Post by ScottieJ » Mon Nov 05, 2012 9:43 am
It's funny you should mention that Darrell as I started to compile some propshaft info for a thread on the friday before I went to France last week because I want to swap to a yota rear prop so was doing some research into lengths etc. ;) I'll get it started at lunchtime and also do soem measuring in the workshop this evening with the propshafts that I have lying around :thumbup:
juncopartner
Post by juncopartner » Thu Nov 15, 2012 12:47 pm
LJ propshafts have the same PCD as very early SJ's up to about late '83ish, they also used the same style solid propshafts as well, but obviously in different lengths. After that the SJ's used a larger diameter hollow propshaft which also used a different PCD. I used to remove the flanges though and swap them round on the diffs so I could swap the diffs around to raise or lower gearing. I was told you are not supposed to do that, (can't remember why though, something to do with setting up the diff!!!) but all I will say I did many 10's of thousand miles like that with no problems.
pro4x4@hotmail.com
Post by pro4x4@hotmail.com » Thu Nov 15, 2012 8:39 pm
Thanks for that mate. The PCD on my LJ Shaft is alot smaller than any SJ shaft or spacer I can find, but thanks for the heads up gives me hope I might be able to find an early spacer or shaft that might do the trick.. As for the flange swaps, when u remove the nut u alter the preload on the pinion bearings.. These nuts are torqued to set the load, but providing u dont do them up to tight or leave to much float ull get away with it.. Thanks for the info mate..
