auto free wheeling hubs ???????????????????
bobjs
Post by bobjs » Sat Dec 01, 2012 12:27 pm
Hi Guys
I had a set of free wheeling hubs on my 20l diest vit and when i siold it i took them off and fitted them to my 1.6 petrol auto,
all i did was remove them from one to the other and since then it seems that my little 1.6 petrol will not go into 4 wd.
i have changed them over off side to near side etc and still the same.
select 4 wd and move forward nothing happens to the front wheels all the drive is still on the back, no clicking as if they where trying to engage etc.
i did no prep the the car at all just removed and fitted the auto hubs to my 1.6 and placed the ones on it onto the old diesel etc.
can you help.
bob.
Re: auto free wheeling hubs ???????????????????
Post by ROBBIE » Sat Dec 01, 2012 5:01 pm
Auto hubs they are normally air or electric activation so wont lock if this isn't connected
Post by ScottieJ » Sat Dec 01, 2012 7:54 pm
Some are just mechanical I think robbie.
Personally I'd just bin them and gets some manual ones, automatic ones always seem to fail when you need them most!
Post by ROBBIE » Sat Dec 01, 2012 8:33 pm
ScottieJ wrote:Some are just mechanical I think robbie.
Ive only seen the air on jimnys where the air lines split and electric on a vit but yeah i would chuck them
bobjs
Post by bobjs » Wed Dec 05, 2012 7:58 pm
i had these on my 2lt diesel and they worked fine, just wanted to ask did i need to do anything to the hubs before i attached them,
like: remove a circlip or something, as all i did was remove them from the diesel and fitted them onto the petrol vit ??
bob.
Post by ROBBIE » Wed Dec 05, 2012 8:18 pm
When you removed them did you have to do anything special or did you just unbolt them?
bobjs
Post by bobjs » Wed Dec 05, 2012 8:36 pm
Hi Robbie
nothing special bud,
just unbolt then place on the other truck,
the diesel had failed its mot on loads of stuff so i was taking off what i wanted to keep for the wee petrol boy.
thank you
bob.
Post by ROBBIE » Thu Dec 06, 2012 7:41 pm
After a bit of a search i found this http://www.suzuki-forums.com/suzuki-sid ... moval.html not the greatest amount of info but might be of some help
bobjs
Post by bobjs » Sat Dec 08, 2012 12:56 pm
cheers robbie
ill have to leave them for now as i will need to strip them down and have a look, i think they are not fixed sides ( ie: one HAS to go on the left and the other on the right etc) but im out of work just now and will have to keep them on there until i have time to have a look,
thank you
bob.
Post by Darrell » Sat Dec 08, 2012 1:36 pm
You've been fighting with those for months :D
Found a workshop manual since I last posted up some info on "Difflock".
Robbed the auto hub section :thumbup:
Auto hub 3.jpg (248.67 KiB) Viewed 6557 times
Auto hub 2.jpg (219.3 KiB) Viewed 6557 times
Auto hub 1.jpg (249.49 KiB) Viewed 6557 times
