Headlight
Re: Headlight
Gardiner wrote:I think I might have electrical problems.
Initial issue is turn the ignition on and passenger side headlight comes on !!!
Also do the headlights have a permanant power mine has is this right ???
Yes most of them are switched earth, so have a permanent live. (Spanish built ones often have the opposite).
- Headlamp Circuit.jpg (120.99 KiB) Viewed 8813 times
Re: Headlight
Ok so it is every chance I have a Earth problem How many and where are the Earth connections in engine compartment supposed to be.
- Tramp
Re: Headlight
How do the head lights behave normally? do they both work? full beam too? the earth is common to both lights so I don't think it will be an earth point playing up, to me it seems like the cable has broken or disconnected itself and is touching earth, if it was still connected you would have issues with both lights, is the low beam filaments ok on the drivers side?
Re: Headlight
OK so the plot thickens this what I have now
Ignition Off All Dipped/Main Beam and Flash work fine and OK
Ignition On And Engine Running Lights All Good.
Ignition On Lights Turned Off both headlights are on but Not as Bright as Dipped possibly 50% as bright turn lights on and seem fine.
Its 1986 so I think "Running Lights" arnt a option.
Re: Headlight
Sounds like you have one of these jobbies hidding under the glove box.
Any more problems just unplug it........
Re: Headlight
What is that then ?????????????
Re: Headlight
More info here http://suzukiclubuk.co.uk/forum1/viewto ... m/start,0/
Re: Headlight
And why the wire to the dash light, What's that all about
- link .jpg (142.92 KiB) Viewed 8455 times
Re: Headlight
I wired my fog light onto its own circuit even when the dim dip unit still worked. I have a feeling the same thing happened with the lights when mine packed up, worked ok when it came off the road then after the rebuild it went wrong
