Headlight
Gardiner
Headlight
Post by Gardiner » Wed Dec 05, 2012 8:37 pm
I think I might have electrical problems.
Initial issue is turn the ignition on and passenger side headlight comes on !!!
Also do the headlights have a permanant power mine has is this right ???
Re: Headlight
Post by Darrell » Wed Dec 05, 2012 9:55 pm
Gardiner wrote:I think I might have electrical problems.
Yes most of them are switched earth, so have a permanent live. (Spanish built ones often have the opposite).
Headlamp Circuit.jpg (120.99 KiB) Viewed 8999 times
Gardiner
Re: Headlight
Post by Gardiner » Thu Dec 06, 2012 6:53 am
Ok so it is every chance I have a Earth problem How many and where are the Earth connections in engine compartment supposed to be.
Thanks
Re: Headlight
Post by Tramp » Thu Dec 06, 2012 6:11 pm
How do the head lights behave normally? do they both work? full beam too? the earth is common to both lights so I don't think it will be an earth point playing up, to me it seems like the cable has broken or disconnected itself and is touching earth, if it was still connected you would have issues with both lights, is the low beam filaments ok on the drivers side?
Gardiner
Re: Headlight
Post by Gardiner » Sat Dec 29, 2012 6:11 pm
OK so the plot thickens this what I have now
Ignition Off All Dipped/Main Beam and Flash work fine and OK
Ignition On And Engine Running Lights All Good.
Ignition On Lights Turned Off both headlights are on but Not as Bright as Dipped possibly 50% as bright turn lights on and seem fine.
Its 1986 so I think "Running Lights" arnt a option.
Re: Headlight
Post by Darrell » Sat Dec 29, 2012 6:58 pm
Sounds like you have one of these jobbies hidding under the glove box.
dip-dim unit.jpg (34.35 KiB) Viewed 8686 times
Any more problems just unplug it........
Gardiner
Re: Headlight
Post by Gardiner » Sat Dec 29, 2012 9:36 pm
What is that then ?????????????
Re: Headlight
Post by Darrell » Sat Dec 29, 2012 9:50 pm
Re: Headlight
Post by Darrell » Sun Dec 30, 2012 2:23 pm
dip-dim unit wiring.jpg (170.73 KiB) Viewed 8641 times
So why run the foglight wires to the dip-dim unit at all, stupid Suzuki :D
And why the wire to the dash light, What's that all about :er: :D
link .jpg (142.92 KiB) Viewed 8641 times
Re: Headlight
Post by ScottieJ » Sun Dec 30, 2012 5:41 pm
I wired my fog light onto its own circuit even when the dim dip unit still worked. I have a feeling the same thing happened with the lights when mine packed up, worked ok when it came off the road then after the rebuild it went wrong :lol:
