So will i need to rerun the rear fog light wiring??????
Also will I need to sort out oil pressure light????
Gardiner wrote:Ok so disconnected as said lights are now working normal.
So will i need to rerun the rear fog light wiring?????? Only needs linking if it no longer works, give it a try![]()
Also will I need to sort out oil pressure light???? No it should be fine, just can't think why it has a wire running to it.
They're a Land Rover part built by Spaniards. What do you expect?dan_2k_uk wrote:The dim-dip unit strikes again. Mine was playing silly games the other day. Then suddenly its fine again.
I didn't think any Jap built SJs had the dimmer units. I was under the impression that the Santana factory made and fitted them because of some Spanish vehicle requirement.ScottieJ wrote:??? You sure about that Ed mines, I doubt the jap built ones use Santana supplied parts.
That might explain why a lot of old american cars in films headlights go off when they stall. The first scene that springs to mind is in 2 Fast 2 Furious when the blue Camaro wipes out. When the engine stops the headlights go with it.Darrell wrote:Thank's
