12callum
Post
by 12callum » Thu Jan 03, 2013 9:11 pm
With all the rain we've had at least the beast got to see some of it, even if it was just sat in the garage!!!
- image.jpg (862.52 KiB) Viewed 6069 times
Also a pick to confirm that I have put it on the wrong way!!!! Silly me
- image.jpg (754.1 KiB) Viewed 6069 times
Also anyone know what these are and if I need them with the webber carb?
Or can anyone see anything I've done wrong as hopefully tomorrow she will be finished off and hopefully started for the first time in over a year!
- image.jpg (518.97 KiB) Viewed 6069 times
- image.jpg (643.2 KiB) Viewed 6069 times
dazerede
Post
by dazerede » Thu Jan 03, 2013 9:20 pm
same about the flood as my garage roof leaks a bit as it is made of felt and doesnt last long but soon it will all go and there shall be a double garage
im a 410 man really so i cant help u on ur 413
4” calmini lift kit
Post
by donkeychomp » Thu Jan 03, 2013 11:21 pm
Hard to tell what that is...might be the oil pressure switch?
Alex
Post
by dan_2k_uk » Thu Jan 03, 2013 11:32 pm
Dont know what they are exactly but some kind of vaccum for the old carb.
Anyway I know you need to blank them. Just put the hoses onto each other or put a screw down the hose.
As long as nothing can get in or out it will be fine.
12callum
Post
by 12callum » Thu Jan 03, 2013 11:51 pm
I have been searching the web for the webber carb info, it seems as though the one that most of you have posted about, is different to mine! I'm going to see if I can change it over tomorrow, will I still be able to use the gaskets or will I have to get some new ones? If not does any one have an SU carb with adaptor that I can buy or maybe swap either way?
Post
by dan_2k_uk » Fri Jan 04, 2013 12:01 am
gaskets will be alright if they've only been fitted for a bit and engine not used in anger. Just remove it carefully.
Would just stick with what you have now as its going to be your quickest easiest route to getting it running.
Dan
Post
by Jordi » Fri Jan 04, 2013 12:07 am
Im an SU convert. I know those pipes are vac advance and mine are just blocked off. I know when i converted my SJ carb to a daishitsu carb it didnt have enough pipes so the SJ vac advnces got blocked off too. That still runs fine.
Sorry about the garage. Never makes life easier when stuff like that happens.
12callum
Post
by 12callum » Fri Jan 04, 2013 12:11 am
I think you might be right dan, the sooner I get it running the sooner I can move on to the seats then get it taxed and tested! Are you over this way any time soon?
John
Post
by Darrell » Fri Jan 04, 2013 12:23 am
You don't need either of those valves with a weber. One was part of the auto-choke and the other part of the idle-up system.
- image.jpg (69.3 KiB) Viewed 6019 times
- imaged.jpg (57.38 KiB) Viewed 6019 times
Post
by dan_2k_uk » Fri Jan 04, 2013 12:24 am
I might be out and about tomorrow afternoon as it happens. Depends whether a delivery I'm waoting in for comes early or not.
If I am out and about I will chuck you a PM over
