All at Sea
All at Sea
On the members map I seem to be 10 miles out in the North Sea, off the Norfolk coast when in fact I am in Sussex. I know the Jimny is good off road, but come on!
Re: All at Sea
That any better
you need to drag it to where you are when first set up, the map doesn't use your profile location
Re: All at Sea
How do you do that? when I try to drag it it pulls the whole map across.ScottieJ wrote:That any betteryou need to drag it to where you are when first set up
Re: All at Sea
might still be issues with the map to be honest, It was designed to work with an older version of PHPBB and I think the developers gave up on it so it doesn't work as well as it used to, I'll move you
Re: All at Sea
When you are in the user control panel and go to set the location, the map will always start with your marker bang in the middle. If you hover your mouse pointer over it, it will change from an arrow to a hand.
This means you are over the marker, then pick up and move.
As Scottie says, its an old map. I've been trying to get it working properly again for a while but its not playing ball!
Re: All at Sea
everytime I go to search for the location it just throws me back out onto the forum, Only way I seem to be able to move markers in in the ACP
Re: All at Sea
Hmmm yes the search doesnt work! I will have a fiddle around with it when I get home!
Re: All at Sea
Cool !ScottieJ wrote:might still be issues with the map to be honest, It was designed to work with an older version of PHPBB and I think the developers gave up on it so it doesn't work as well as it used to, I'll move you
I'm in Sussex now, thanks
Re: All at Sea
The best place to beThe Zee wrote:Cool !
Re: All at Sea
I am often in Shoreham on the beach with my dog.twiss wrote:The best place to beThe Zee wrote:Cool !
