Front gearbox oil seal emergency!!!
How much? Where from? How to do it!!!!
Help urgently required!!!!!
Presuming thats what it is as the oil is coming out the bottom of the bell housing
- Ladaman
- Suzuki Guru
Re: Front gearbox oil seal emergency!!!
Or is it engine oil and the crank seal has gone?
Gearbox oil. Smell and taste checked.
Yum yum!!!Jordi wrote:Gearbox oil. Smell and taste checked.
Just gotta see how it develops. Not sure if it is gonna be an issue. Just dribbled a bit while i was doing the brakes then stopped. Its been out again and hasn't leaked anymore.
- suzukisteve
- Suzuki Guru
worse case you can always put a stop leak treatment in as a temp fix until after you get back mate
pickle power!
Stop leak in the gearbox?
Just thickens the oil to slow it down.Jordi wrote:Stop leak in the gearbox?
I guess you can just take that from cover off to replace the oil seal but then you will need a gasket for that too.
According to the tinternet.......................A 413 / samurai has...............
- Untitled.png (490.18 KiB) Viewed 4505 times
I am right in thinking its just take the cover off behind the release bearing. Swap seal & refit?
