hi rear wheel bearings easy or hard 2 replace
carlsush
Post by carlsush » Tue Sep 10, 2013 11:58 pm
r rear wheel bearings hard 2 do on a suzuki samurai
Re: hi rear wheel bearings easy or hard 2 replace
Post by turbo-tom » Wed Sep 11, 2013 12:27 am
Nope. Ideally you need a press.
timwilks13
SCUK Website Padawan
Post by timwilks13 » Wed Sep 11, 2013 1:38 am
Only done em on a 410, if they are similar then ideally a press is good, otherwise an angle grinder and metal chisel will get em off and some scaffolding bar and some force will put em back. Don't clamp the bearing in a vice and hit the half shaft though to get em off, can damage the teeth at the end doing that!
carlsush
Post by carlsush » Wed Sep 11, 2013 7:34 am
looks likethe grinder will do the job then
Post by Jordi » Wed Sep 11, 2013 8:19 am
Cut the off with a grinder and can be persuaded back on.
Post by ScottieJ » Wed Sep 11, 2013 9:12 am
carlsush
Post by carlsush » Wed Sep 11, 2013 3:15 pm
thanks 4 the help :doublethumbs:
carlsush
Post by carlsush » Wed Sep 11, 2013 7:19 pm
just got a axle 4 40 quid so win win
