hi rear wheel bearings easy or hard 2 replace
r rear wheel bearings hard 2 do on a suzuki samurai
- turbo-tom
Re: hi rear wheel bearings easy or hard 2 replace
Nope. Ideally you need a press.
- timwilks13
- SCUK Website Padawan
Only done em on a 410, if they are similar then ideally a press is good, otherwise an angle grinder and metal chisel will get em off and some scaffolding bar and some force will put em back. Don't clamp the bearing in a vice and hit the half shaft though to get em off, can damage the teeth at the end doing that!
looks likethe grinder will do the job then
Cut the off with a grinder and can be persuaded back on.
thanks 4 the help
just got a axle 4 40 quid so win win
