Bolt size ?
The Bird Man
Bolt size ?
Post by The Bird Man » Sun Sep 22, 2013 2:03 pm
Afternoon chaps, does anyone know the bolt size for the bolts that connect the body to the chassis please ? If it's any help it has a number 7 on the head :) Thanks in advance, Eddie.
Re: Bolt size ?
Post by Darrell » Sun Sep 22, 2013 2:49 pm
The number 7 denotes it's strength and tightening torque.
Which bolts are you after, not that I have any :oops:
Chassis mounts.jpg (60.26 KiB) Viewed 6028 times
The Bird Man
Re: Bolt size ?
Post by The Bird Man » Sun Sep 22, 2013 3:02 pm
Hi Darrell, thanks for taking the time to reply. It's the ones that bolt onto the cross member, the ones that fit into the cone shaped body mount ;)
Re: Bolt size ?
Post by Darrell » Sun Sep 22, 2013 3:22 pm
I'll be honest I'm a bit confused. I've never taken the body off but I believe other than the ends they are captive bolts. If this is the case you would not be able to see a bolt head with a number on it??
The others are standard M10 bolts. My searching says they are 40mm long, but I have no idea.
Plenty of the guys have taken the body off so hopefully they can give you better info later :thumbup:
My take of it ??
Untitled - 1.jpg (74.13 KiB) Viewed 6020 times
Re: Bolt size ?
Post by Darrell » Sun Sep 22, 2013 3:24 pm
I trust yours hasn't had a body lift fitted..
Just a thought :er:
Re: Bolt size ?
Post by Darrell » Sun Sep 22, 2013 3:27 pm
Robbed this from the manual..
Suzuki bolt ratings.png (747.42 KiB) Viewed 6017 times
The Bird Man
Re: Bolt size ?
Post by The Bird Man » Sun Sep 22, 2013 3:46 pm
Cheers Darrell ;) By the looks of things the ones I am after are the captive bolts. The reason I can see the heads are because the paint covering them has been stripped back :) Problem is though they are welded on so to replace them going to have to get the grinder out instead of just a straight forward unbolt :roll: Also while I'm here, when I have got them sorted and the body ready to back on the chassis I have six hockey puck looking body mounts, I assume they are to with the cone shaped ones ? But how would they go together ?
Re: Bolt size ?
Post by ScottieJ » Sun Sep 22, 2013 7:37 pm
Odd you should not be able to see the bolt heads for the captive ones? They are under the floor, you can't remove them without cutting holes in your SJ?
Re: Bolt size ?
Post by dan_2k_uk » Sun Sep 22, 2013 7:43 pm
Think you can see the heads of the ones behind the front seats that are against the side of the transmission tunnel.
Re: Bolt size ?
Post by dan_2k_uk » Sun Sep 22, 2013 7:44 pm
Oh and just to confirm. The info Darrell gave regarding which are captive and which pass through the body is correct.
