Anyone replaced / fab'd up a floor pan?
Post by Jordi » Fri Oct 25, 2013 3:17 pm
Thinking about replacing the floor pan. Most likely with a home brew job. Just wondered if anyone had done this? Any photos?
suzukisteve
Re: Anyone replaced / fab'd up a floor pan?
Post by suzukisteve » Fri Oct 25, 2013 6:20 pm
I know scottie has done the rear but I haven't seen a front floor pan done bud. I suppose as long as you get the right measurements its doable. might have to watch out for body warp if replacing the lot at once I reckon
pickle power!
waynesworld
Post by waynesworld » Fri Oct 25, 2013 6:43 pm
Hi kida, not done one myself, well a full floor pan but where do you have the worrys? or need thoughts?
Its justa case of cutting out the old and fitting a new isnt it, well it all i ever do, if its needs a few profiles then a good lump hammer and bolster chisel will help out loads alomg with a BIG vice or a couple of breeze blocks, unless you have a sheet metal bender.
wolly
Post by Jordi » Fri Oct 25, 2013 6:49 pm
Thinking about whipping the off and doing the floor. Or maybe another tub.
kiwizook
Post by kiwizook » Fri Oct 25, 2013 7:27 pm
I'll get some pics when I fix mine up. it's not the complete floorpan, but it's the worse area's
waynesworld
Post by waynesworld » Fri Oct 25, 2013 7:45 pm
Jordi wrote:Thinking about whipping the off and doing the floor. Or maybe another tub.
I cant remember what they are like, are they a bit more than flat as for the reason to ask mate
