windscreen rubber leaking :(
Jay18
Post by Jay18 » Wed Nov 06, 2013 4:27 pm
the mrs has been complaining about the floor being wet and that her trainers she leaves in the floor pan are wet so i cleaned out the vent under the windscreen on the outside, but wasnt sure about that being the cause so i took the little plastic bit on the top of the dash on the passenger side where the wiper motor and bolt for dash is and there is a little leak coming through the windscreen rubber :(
is there an easy way of fixing this? without removing the screen or rubber, any sort of screen rubber refurbisher to soften the rubber up?
think i might have to use silicone on the inside to stop the leak if it will work..
2003 Grand Vitara 2.0 16v
16x7 Black 8 spokes
Nexen road tyres
32mm spacers
Kenwood Double Din Head Unit
Hidden CB radio
Cruise Control
GV Build Thread
SJ Build Thread
Facebook
SuzukiPicsUK on Instagram
Re: windscreen rubber leaking :(
Post by dan_2k_uk » Wed Nov 06, 2013 4:32 pm
Lift the rubber on the outside and clean under the rubber and the screen surround and seal it with a high quality polyurethane adhesive.
Or just rip the carpet up and leave the bungs out! :evil:
Post by ScottieJ » Wed Nov 06, 2013 4:36 pm
Tell her not to leave her trainers there then :thumbup:
timwilks13
SCUK Website Padawan
Post by timwilks13 » Wed Nov 06, 2013 4:50 pm
i had that on my old windscreen, just took the windscreen out and the rubber off, gave the rubber, glass and windscreen a good ol' clean and put it back together.
Post by twiss » Wed Nov 06, 2013 5:19 pm
Just be very careful with the screen while you're removing it! ;)
ferris
Post by ferris » Wed Nov 06, 2013 5:45 pm
Mine's been leaking for a few years now. I went for the remove the carpets and take the bungs out solution. One day il get round to fixing it properly :lol:
Post by Edweird » Wed Nov 06, 2013 6:29 pm
I use old newspapers under the carpet to soak up the moisture and replace them occasionally.
Post by Jordi » Wed Nov 06, 2013 6:41 pm
Never leaked but I do the same as Tim, screen out and give the glass, rubber and frame a damn good clean and refit.
Post by ROBBIE » Wed Nov 06, 2013 7:06 pm
I've always got water when it rains, have no idea where it comes in. I've done the heater, changed the screen and replaced the seal where the screen folds. I have even had the dash out and had someone hose the car while I hunted for leaks and yep that was the only time it stayed dry :er:
Now there is no carpet or bungs. Passengers learn not to streech their feet out in the rain :D
dazerede
Post by dazerede » Wed Nov 06, 2013 7:08 pm
A bit of rain comes in.threw the top od the door I know it sounds strange but when I fully close the door there is a gap at the top of the door
4” calmini lift kit :)
