Won't start
george123
Won't start
Post by george123 » Tue Dec 31, 2013 7:04 pm
Hello all iv managed to get a spark to my sj and fuel is going through but I can't seem to get her started? Any help thanks
Re: Won't start
Post by Jordi » Tue Dec 31, 2013 7:14 pm
How long since it was last ran? Is it running the original carb?
george123
Re: Won't start
Post by george123 » Tue Dec 31, 2013 7:36 pm
Was running fine 2 years ago buts it's been stood for 2 years haha and yeah it's running original carb
timwilks13
SCUK Website Padawan
Re: Won't start
Post by timwilks13 » Tue Dec 31, 2013 7:47 pm
engine i just put in mine must have been sat for years without running, just kept it on starter for about 5 mins before it kicking in to life, is it a 410 or 413?
Re: Won't start
Post by Jordi » Tue Dec 31, 2013 7:51 pm
Get a screen wash size cap, fill it with petrol, while some one is turning it over pour it directly down the carb. Repeat a couple of times (3-4 max) if it doesn't fire carb is probably goosed.
george123
Re: Won't start
Post by george123 » Tue Dec 31, 2013 7:55 pm
It's a 410 and okay where is this cap cuz the only one I see is on the from of facing towards the rad which drains it out where the float is
Re: Won't start
Post by Jordi » Tue Dec 31, 2013 8:06 pm
It needs pouring in the carb aperture where it sucks the air through.
Not so easy on 410s as they are side draft carbs. Much easier on down draft carbs. You can use a small squeeze bottle to squirt the petrol into the carb but keep it small and petrol volumes to a minimum. It only take a thimble full to make them fire. If you have too much and it backfires badly you will lose any hair / receive 3rd degree burns.
Carb may need a clean through. Is the fuel getting through the carb?
Easy guide is to blow through the pipe that goes from the fuel pump to the carb. Disconnect it from fuel pump and blow. Will tell you if carb is blocked.
dazerede
Re: Won't start
Post by dazerede » Tue Dec 31, 2013 8:10 pm
Ye thats the best option squesy bottle filled with fuel and squirt with fuel inthe carb and it will start
4” calmini lift kit :)
george123
Re: Won't start
Post by george123 » Tue Dec 31, 2013 8:15 pm
Yeah like jordie said it's on the side so I don't know how going to do it
Re: Won't start
Post by Darrell » Tue Dec 31, 2013 8:20 pm
You need a tin of this..
It's out there and it works.
:D
