Restoring a SJ van body.
- HuwJones
I've just bought a SJ van body, it's a 1988 SJ 410. I've bought it to replace the soft top body on my current SJ.
The van needs a bit of work, new rear arches, a bit of welding on the passenger side sill and a few minor dents to be removed. The footwells, bulkhead and everything above the floor look to be rot free. I've gone around with a small hammer tapping in various places and everything seems solid (apart from the list I mentioned earlier). I'm now not sure what to do, either cut all of the rust out, patch up and paint. Or do I send it off for sandblasting first?
I'm also going to hand paint it, as I haven't got enough room to spray, does anyone have any tips or tricks on hand painting?
Huw
Huw
1) The Right Way,
2) The Wrong Way
3) My Way.
2 & 3 are usually the same.
1) The Right Way,
2) The Wrong Way
3) My Way.
- donkeychomp
Re: Restoring a SJ van body.
If you can afford to get it blasted and are confident enough the thin bodywork will stand it then go for it. As for hand painting I'd advise against it if you want a decent finish. (loads here will disagree with me!)
Brush paint on.... Go offroading
- donkeychomp
- HuwJones
I'm not planning on doing any major off roading, maybe once or twice a year max. I just want to turn this one into a reasonably reliable run around that keeps me dry! The whole reason I'm changing it to a tin top is that I'm fed up with the soft top pissing on me!
I was planning on hand painting it as I haven't got the space to spray paint it, it just barely fits into the garage with enough room to walk around it.
Huw
Huw
1) The Right Way,
2) The Wrong Way
3) My Way.
1) The Right Way,
2) The Wrong Way
3) My Way.
I have seen many brush or roller painted SJs (including my own) which I consider to be an acceptable finish.
Heres mine just after I finished with a 2 inch brush.
- turbo-tom
Im a spray type of guy. But when I saw Dan's Scott's and now steves sj's you really wouldnt of thought they would of been hand painted from a distance.
Imo it depends on the prepwork, paint grade/type and ofcourse the artist/ painter.
Tom
Ford Fiesta ST
Ford Fiesta ST
Depends on the finish your after.
Rolling and some elbow grease can get amazing results
http://www.rickwrench.com/index79master ... paint.html
Painted with a roller
- polished4.jpeg (67.08 KiB) Viewed 8019 times
- HuwJones
Wow, that finish is amazing! I'd like to point out that I'm not aiming towards that standard. If it looks good from 6ft away, it's good enough for me!
1) The Right Way,
2) The Wrong Way
3) My Way.
1) The Right Way,
2) The Wrong Way
3) My Way.
