Lwb and swb gearbox.
b3n16
Post by b3n16 » Sat Nov 23, 2013 6:30 pm
It's only a quick one and any help will be massively helpful. Can any one confirm if the Lwb gearbox from a 1.6 Vitara fit a swb Vitara still 1.6. Many thanks
trotter
Re: Lwb and swb gearbox.
Post by trotter » Sat Nov 23, 2013 6:50 pm
Can't see why the gearbox would be different?
if in doubt, FLAT OUT!
b3n16
Post by b3n16 » Sat Nov 23, 2013 6:59 pm
This is good :D won't be different mounts or anything?.
trotter
Post by trotter » Sat Nov 23, 2013 7:20 pm
I don't know for sure but as far as I know engines and gearboxes would be the same it would just be he length of axle props that would be different
b3n16
Post by b3n16 » Sun Nov 24, 2013 10:26 pm
Brilliant. Thank you for help mate
trotter
Post by trotter » Mon Nov 25, 2013 12:04 am
No worries
robbymp
Post by robbymp » Fri Jan 31, 2014 3:39 pm
Did you find out if it fitted ok mate I'm just about to buy one but I'm unsure and don't seem to be able to find anymore information on the web!
Post by dan_2k_uk » Fri Jan 31, 2014 6:40 pm
All 1.3 gearboxes are physically the same size.
413 and Sammy boxes have slightly differing 5th gear ratio.
Post by Jordi » Fri Jan 31, 2014 6:43 pm
I presume the gear boxes are all the same.
Mounts may be different but your existing mounts would swap over.
(it's for a Vit Dan)
Post by dan_2k_uk » Fri Jan 31, 2014 7:06 pm
I'm a tard!
