Fuel pump for 16V MPI in SJ
Reg 270
Post by Reg 270 » Thu Jan 30, 2014 8:19 pm
Hi, I'm new to the forum and this question may have already been addressed.
I intend fitting a Vit 16V mpi in my SJ.
Do I need an in tank fuel pump or can I use an inline one eg. Facet, and at what pressure should it be be run at?
Also do I need a fuel return pipe pluming in?
Thanks for any help
Rhinoman
Re: Fuel pump for 16V MPI in SJ
Post by Rhinoman » Thu Jan 30, 2014 8:54 pm
You can use an inline pump but they are noisier than an internal pump. You need to be able to run at up to 50psi, the actual pressure is set by the regulator on the fuel rail.
Reg 270
Post by Reg 270 » Thu Jan 30, 2014 9:44 pm
Thanks Rhinoman, can a pump be fitted into a SJ tank?
Rhinoman
Post by Rhinoman » Thu Jan 30, 2014 10:01 pm
You'd have to modify it or fit an EFi Sammy tank.
Reg 270
Post by Reg 270 » Fri Jan 31, 2014 5:28 pm
Thanks again, is the mod easy to do?
Where would I get an EFi tank?
Rhinoman
Post by Rhinoman » Fri Jan 31, 2014 5:41 pm
I've never modded the tank, I think that you would need to weld a new mounting flange on the tank. Try eBay for an efi tank.
gp7186
Post by gp7186 » Fri Jan 31, 2014 6:04 pm
I modded my original tank. There is a pressing on the tank where the pump fits it looks a bit like a flower. I drilled a 70mm hole in the centre and removed the flange from the vit tank (spotwelds) and then welded this to the sj tank centralising it over the hole I had drilled. If you do this empty the tank of fuel and the fill with water so it dont go up in flames on you. When done empty the tank of water and make sure all swarf is removed before fitting it. I also braized an 8mm fuel return line in while fitting the pump
