Headlining Removal in a Tin top.
- HuwJones
Hi guys,
I'm currently stripping down a 410 van. How to I remove the headlining without damaging it? I want to take it out so I can knock a dent out of the roof and to replace the fabric. So keeping it in one piece would be useful. I've already removed the bracket that runs across the middle of the roof.
Huw
Huw
1) The Right Way,
2) The Wrong Way
3) My Way.
2 & 3 are usually the same.
1) The Right Way,
2) The Wrong Way
3) My Way.
Re: Headlining Removal in a Tin top.
i dont know if you can remove it without ripping it or seperating the vinyl from the foam, when i done mine i just ripped it all out and then washed it over with some washing up liquid and warm water
then glued some carpet underlay to the roof, then put 3mm ply up and glued van mat to that, it looks clean and tidy and deadens alot of the noise...
2003 Grand Vitara 2.0 16v
16x7 Black 8 spokes
Nexen road tyres
32mm spacers
Kenwood Double Din Head Unit
Hidden CB radio
Cruise Control
GV Build Thread
SJ Build Thread
Facebook
SuzukiPicsUK on Instagram
16x7 Black 8 spokes
Nexen road tyres
32mm spacers
Hidden CB radio
Cruise Control
GV Build Thread
SJ Build Thread
Just rip it out, that's my plan. I'm just gonna get acoustic carpet / foam stuff and glue it back on.
Id be inclined to cut across where the roof support goes across and remove it in
Two halfs. Then when you refit it the join
Is behind the bar.
I never refitted the bar in mine after I done my headliner tho
Is behind the bar.
- timwilks13
- SCUK Website Padawan
Understandable, you didnt want that big old bar getting in the way of your 1800's Virginia Creeper wallpaper!andyrew wrote:Id be inclined to cut across where the roof support goes across and remove it in
Is behind the bar.
Er. My roof lining was hanging down and generally minging. I ripped it down and removed the foam backing. I decided to glue up some acoustic liner, but after getting more glue on me than the roof I thought sod it and just painted it with underseal. It stank for weeks
, silly bugger !!
- HuwJones
Sounds like a plan. I'd like to keep it in one piece in the off chance that I could remove the old fabric and put something a bit nicer on the side that you see and some carpet or acoustic mats on the top.andyrew wrote:Id be inclined to cut across where the roof support goes across and remove it in
Two halfs. Then when you refit it the join Is behind the bar.
My eventual plan is to try and get the SJ to be as quiet as possible, so I'm going to line the floor, roof and the removable panels on the sides in the back with acoustic mating.
Thanks for the info.
Huw
1) The Right Way,
2) The Wrong Way
3) My Way.
1) The Right Way,
2) The Wrong Way
3) My Way.
- Ladaman
- Suzuki Guru
Just get some ear defenders.
£5, job sorted.
£5, job sorted.
TypicalLadaman wrote:Just get some ear defenders.
£5, job sorted.
- HuwJones
Haha I did that a few times, but I couldn't hear the radio. One of the locomotives at work is nicknamed "Uproar" and it's mandatory to wear hearing protection. The cab is basically a tin box bolted to the to of the gearbox and part of the engine. It gets to about 92dB when going full pelt!Ladaman wrote:Just get some ear defenders.
£5, job sorted.
Huw
1) The Right Way,
2) The Wrong Way
3) My Way.
1) The Right Way,
2) The Wrong Way
3) My Way.
