Inclinometer my way
Inclinometer my way
Many moons ago the little door on the dash of my jap sami
Fell off. But I struggled to find a good one to replace it.
(Spanish sami ones are a shinny finish and it would bug me)
Ive had a empty hole with just crappy change and rubbish.
At wagtail I got showered in 5p coins and other irritatingly small things
when I hoofed up a small But steep incline.
I like the factory inclinometer but there's no way im paying
The prices they go for!
So after the brutal attack my aftermarket inclo did to me
I ripped it to bits! And decided to start making a better version
- 20140120_174059.jpg (2.64 MiB) Viewed 11266 times
- 20140120_164819.jpg (2.66 MiB) Viewed 11266 times
- 20140120_164813.jpg (2.33 MiB) Viewed 11266 times
- donkeychomp
Re: Inclinometer my way
Nice work as usual matey. I need to get one of those!
- muddymesser
looks good . . . will be interesting to see if it site level when its in
I thought this too but its basically two gears and a weight.muddymesser wrote:looks good . . . will be interesting to see if it site level when its in
So I just disengaged the gears and repositioned the weight
Now the dial reads level
- Tramp
I'm impressed and looking forward to see it fitted, I've wanted one for ages and this might be a lot better than a standard one! Or at least cheaper!
looks good man! I think I might rethink my dash Idea and put a phone in that slot... go back to the standard temp gauge and replace the cluster with a working one!
if i can do it anywhere near as tidy as that I'll be impressed
Next step is a bit overkill but im a bit of a factory look
Person. I noticed that the old door is not completely
Flat so ive cut the door in half and stuck the two pieces
And the new frame down on a flat surface and skimmed
Over with filler to match the radius of the panel around the clock
Ill get some photos when ive finished the prep
- 20140122_160351.jpg (2.11 MiB) Viewed 11235 times
- Tramp
When i bought mine it already had this installed on the dashboard.....these were on ebay for about 12 pounds each seems to work quite well, also the unit on its right which is a rev limiter come resettable audio warning that one can set the rpm to
- PDR_0062.JPG (391.23 KiB) Viewed 11025 times
Sorry rev limiter not in the picture
jim
jim
