wheel help
timwilks13
SCUK Website Padawan
wheel help
Post by timwilks13 » Thu Mar 06, 2014 11:03 pm
blowing one of my tyres up on a daily basis, the tyre wall has split and then there's a puncture in the same inner tube. Been looking at some other tyres not too far from me, theyre 235/60/15's , only road tyres but they hold air, on rims for £60. My current tyres are 195/70/15, am i right in thinking then that those others are going to be smaller than my current ones? as with my gearing running 195's is bad enough and going any smaller would be horrendous!
Re: wheel help
Post by donkeychomp » Thu Mar 06, 2014 11:28 pm
err...no. These will be a LOT bigger. They might just fit a standard SJ, you might need to get a hammer out and bash in the plates under the front wheel arches.
stevepsj413
Re: wheel help
Post by stevepsj413 » Thu Mar 06, 2014 11:35 pm
Yeah the overall diameter will be slightly smaller but the new tyres will be wider, the 235/195 refers to the tyres width, a 195 tyre is roughly 7.5 inch wide and the 235 is roughly 9 inch wide. Its the 70/60 bit that makes a difference to the size, this is the height of the tyres side wall, there wont be much difference but they will be slightly smaller.
Re: wheel help
Post by donkeychomp » Thu Mar 06, 2014 11:54 pm
Smaller? 195 equals an overall diameter of 634mm. 235 is 686mm.
Re: wheel help
Post by Darrell » Fri Mar 07, 2014 12:15 am
195 235 is the width......
timwilks13
Re: wheel help
Post by timwilks13 » Fri Mar 07, 2014 8:39 am
yea thats what i thought, ill leave it then, ill stick with just blowing this one up till i find something else bigger! thanks guys.
Re: wheel help
Post by donkeychomp » Fri Mar 07, 2014 11:07 pm
err...235's are bigger than 195's. End of.
Re: wheel help
Post by Darrell » Fri Mar 07, 2014 11:12 pm
A gnats fart bigger, but bigger :D
Accord to the calculator 1.38% bigger :thumbup:
Sj410red
Re: wheel help
Post by Sj410red » Sat Mar 08, 2014 9:35 am
I'm running 235/70/15s with spacers and a 4inch lift and alls ok
3" calmini lift springs
6" shackles
Rough Country Shocks
Z bar
32mm spacers
Aisan free wheeling hubs
Roll bar
Snorkel
K&N air filter
Poly bushes all round
Front Diff guard
timwilks13
Re: wheel help
Post by timwilks13 » Sat Mar 08, 2014 1:56 pm
donkeychomp wrote:err...235's are bigger than 195's. End of.
they're wider yes, but smaller in overall diameter.
