Fitting YJ springs to a Samurai
Re: Fitting YJ springs to a Samurai
Looks good!!
Now everything has settled check your Driveline angles, it only takes a few degrees to cause vibes.
- Ladaman
- Suzuki Guru
Thanks guys.
Good news. The vibration was coming from the front prop. I re fitted the standard Samurai one, just to give 4WD. Knowing it was too short really. That's what the problem turned out to be, not enough spline engagement so allowing wobble between the two halves.
Had a drive without it fitted and all is good. Just need to be patient now and get the LJ70 prop back from the fabricators and try that.
Great stuff. Looks like it performs well.
- zukenstein
Ladaman - Looks good any pics of the back springs and how far they stick out at the back, shackle angle etc?
Zuk·en·stein - A monster made from parts of cadavers and brought to life by the power of an electrical charge.
What the fool cannot understand he laughs at, thinking that by his laughter he shows superiority instead of latent idiocy.
- Ladaman
- Suzuki Guru
I will get you some pics Monday night. I've been out today.
Looks brilliant!
- Ladaman
- Suzuki Guru
Here you go. Not the best shot, and I must admit I'm not overjoyed with the extra length on the tail end of the springs, but hey ho. It's all part of the "development" isn't it?zukenstein wrote:Ladaman - Looks good any pics of the back springs and how far they stick out at the back, shackle angle etc?
The upside is, I have just tried my 31's on, and expecting to need to do a virtual lift, but I think I'm going to be OK with just some thinnish front wheel spacers
Who know's if it really bugs me I might just bite the bullet and get some proper YJ's.
- photo.JPG (295.39 KiB) Viewed 7591 times
- zukenstein
cheers Ladaman thanks for that
- Ladaman
- Suzuki Guru
I went to work in the Suzuki today as the weather was nice. at lunchtime I got one of the guys to assist with a bit of a flex test. All looks to be okay, so lets see how it performs at Tong on Sunday.
Will the "protruding" shackles be an issue? Lets wait and see.
- IMG_2482.JPG (1.69 MiB) Viewed 7519 times
- Cyprus Geoff
- Can I have a tow
Looks great, how close to the filler did you get with the new plastic wheel arch
on the drivers side?
