Fitting YJ springs to a Samurai
Ladaman
Re: Fitting YJ springs to a Samurai
Post by Ladaman » Tue Apr 29, 2014 6:33 pm
Mmmm, it overlaps a bit, but I don't use it as my actual tank is in the rear.
I'm sure with a little trimming it could be removed.
Post by Anton » Tue Apr 29, 2014 7:20 pm
Ladaman wrote:I'm sure with a little trimming it could be removed.
Meh. I'd leave it. ;)
Cyprus Geoff
Post by Cyprus Geoff » Wed Apr 30, 2014 5:51 pm
Thanks, Leave it alone if you don't use it!
IIRC a guy on Pirate fitted it in same position and used a heat gun to create a curve in the right place.
Also, I read somewhere about guys replacing the supplied metal screws for the wheel arches with plastic ones so that if the wheel arch gets a big clout, the plastic threads strips instead of ripping the mounting point on the arch extension. Have seen several knackered ones like this. Will see if I can find it.
Edit: here you go: http://www.zukikrawlers.com/showthread.php?t=53453
Ladaman
Post by Ladaman » Wed Apr 30, 2014 7:08 pm
Oh I am leaving it, don't worry.
When I said you could trim I was meaning for you or others who need to access it.
I bought a load of plastic number plate screws to fit mine. I still have a bit of a mix of fasteners at the moment.
1. Some of the holes are blind so I couldn't fit a nut on the plastic bolts.
2. The large head pop rivets I've used and had available were of a certain length.
3. I used large self tappers where the above wasn't possible.
I like, and didn't think of the weld on nut, or thinking about it you can get pop rivet type nuts. Another good possible solution.
Post by ScottieJ » Wed Apr 30, 2014 11:49 pm
Rivnuts are the best thing ever for mounting things like arches, panels and small mounts etc. my roof is held on using them, transmission tunnel cover and gator surrounds etc. loads of little things.
I just have a cheapo rivnut tool like this http://bit.ly/1dNqCNf
Best to use aluminium rivnuts with it though.
