Inlet manifold flaps seized
Has anyone stripped down the inlet manifold , I'm going to have to do it because the inlet manifold flaps are seized and the the linkage to the opening diaphragm has snapped also while I'm doing it I can change the temp sensor what a brilliant place to put it right at the back of the engine.
Re: Inlet manifold flaps seized
I see in your other posts you have a 2003 2.0td 107hp.
Is that the RHZ engine, as I do have a workshop manual for that if needed.
I'm afraid I have no idea what these flaps are
what is a RHZ engine I thought it was a Peugeot engine but I know nothing, last time I played with a car engine it was a 1600 mk1 escort. This is what I've got
- unnamed.jpg (5.98 KiB) Viewed 5787 times
There are 2 types of diesel engine fitted.
RF engine is the Mazda unit and the RHZ is the Peugeot unit.
I've just checked the V5 its the RHW engine so the Peugeot 807 Manual I bought is no good, but on the plus side after a bit of research the RWH is better for remapping
Peugeot twin cam, forgot that one
The one I've never managed to find a workshop manual for
If you ever come across one please give me a shoutDarrell wrote:Peugeot twin cam, forgot that one
