comfortable leaf spring shackles
samurai gary
Post by samurai gary » Sun Nov 09, 2014 11:49 am
Hi. I just found some comfortable leaf spring shackles
on ebay. Designed to make a softer ride
for the sj. Has anyone ever used these
if so are they any good and are they easy to fit.
Re: comfortable leaf spring shackles
Post by Anton » Sun Nov 09, 2014 11:56 am
linkeydink? I'd imagine none of us have used them (never heard of them before) - which either means they're crap and everyone avoids them, or they're too new an idea for anyone to have tried them.
I wouldn't mine a look at them.
If you want a softer ride, have you thought about longer leaf springs and/or PTFE tape between your leaf springs?
samurai gary
Post by samurai gary » Sun Nov 09, 2014 12:13 pm
I have never seen them before either. Quite exspensive
though. Have a look on ebay or google it.
Post by ROBBIE » Sun Nov 09, 2014 12:18 pm
These?
Click Here for Ebay Listing
samurai gary
Post by samurai gary » Sun Nov 09, 2014 12:23 pm
Yes thats them
Post by Edweird » Sun Nov 09, 2014 12:55 pm
They're not braced in any way; I don't like them.
Post by Anton » Sun Nov 09, 2014 1:02 pm
Don't like the idea of those. If they're designed to flex, so as to give you a little extra "spring" in your suspension, then they'll bend laterally too. Imagine your axle under lateral forces as you corner to the right - they bend laterally too and your whole axle moves laterally to the right, causing bumpsteer when there isn't even any bumps.
I thought initially that they would triangulate each other but if they can compress, then it's possible for one shackle on each leaf to compress as it bends laterally while the other stretches as it bends laterally.
This all assumes they're soft enough to actually soak up any of the suspension movement transferred into them.
Let some other nutter try them out first, I have a sneaking suspicion that they're £117.90 worth of scrap and/or impending doom.
You're much better off with UHMWPE tape, I think. You need 2.5 inch wide (I *think*), but you might get away with a 2" roll and a 0.5" roll...
Post by Tramp » Sun Nov 09, 2014 1:09 pm
I can't see how the shackles would make the ride more comfortable, it's the springs & dampers that give the flex and rebound, the shackles are just a pivot point,
Post by dan_2k_uk » Sun Nov 09, 2014 1:42 pm
Complete bullshit. Won't do anything but empty your wallet and fill theirs.
samurai gary
Post by samurai gary » Sun Nov 09, 2014 1:54 pm
Ok thanks for all your advice
