1.6 road speed on 31's
Re: 1.6 road speed on 31's
Post by dan_2k_uk » Tue Apr 22, 2014 2:57 pm
The advance should be set at completely up to temperature with the vac advance pipe disconnected if I remember correctly.
Have you got the vac advance plumbed into the correct side of the SU butterfly. If not you might be already advanced at tickover so none left at the top end.
Post by dan_2k_uk » Tue Apr 22, 2014 2:58 pm
That is a terribly worded post but I know what I mean ^^^^
Post by Jordi » Tue Apr 22, 2014 3:00 pm
Mine all set up my sound and sight. Good for 60 as a cruising speed on the 31s.
timwilks13
SCUK Website Padawan
Post by timwilks13 » Tue Apr 22, 2014 3:18 pm
VAC advance is on the carb side of the butterfly not the manifold side, i do believe that to be correct? when i set the timing i had the vac adv on, so will drive it home later to get the engine warm and do it when when im home
Post by dan_2k_uk » Tue Apr 22, 2014 5:24 pm
It shouldn't be getting hardly any advance at tickover anyway with the butterly closed as you said its on the carb side of the butterfly. Sure I did mine at 10° with it removed though and I know it works.
Post by Anton » Tue Apr 22, 2014 5:26 pm
Yeah, my SJ has problems pulling. Checking the Samurai gear ratio calculator I worked out that with 31's on, each ratio is only marginally lower than the ratio above on a standard sammy (that is, 1st is almost where 2nd should be, 4th is where 5th should be, and so on).
The result is that 5th is useless. Utterly. Yet, I can top 55mph on the speedo (which is probably 65 irl).
I'm at 10 deg at the moment, and I colourtuned it. You should be able to cream my 1.3 powered SJ, but it sounds like you've got similar power levels to me - so it really does sound like you're way out tuning wise.
Shame you're not coming to billing, we could have a go at tuning it for you (I'd bring my colourtune etc).
Post by dan_2k_uk » Tue Apr 22, 2014 5:38 pm
He is coming to billing Anton!
Post by twiss » Tue Apr 22, 2014 5:41 pm
If he makes it ;)
(Rich coming from me I know haha)
Post by ScottieJ » Tue Apr 22, 2014 7:38 pm
If Tim can make it to wagtail running on 3 cylinders I'm sure he can make it to billing with the wrong timing :hahaha:
Post by twiss » Tue Apr 22, 2014 7:43 pm
Will the pistons make it? Place bets now
