A question of stability
Re: A question of stability
Post by ScottieJ » Fri Jul 25, 2014 10:53 pm
donkeychomp wrote:and why are you running 20psi front 26 rear? The front is way to low.
Nope it's factory spec, always ran my SJs at 20psi, I run 18psi with the 33s most of the time because of the heavier sidewalls though.
Post by donkeychomp » Fri Jul 25, 2014 11:32 pm
wow never knew that, seems a very low pressure though. Always run mine at 30psi. I do turn it down offroading, but find that pressure on road is just about perfect.
Post by Edweird » Fri Jul 25, 2014 11:33 pm
I run 24psi all round.
Post by ScottieJ » Fri Jul 25, 2014 11:50 pm
SJs weigh under 1000kg and have high profile sidewalls unlike road cars so don't really need high pressures.
Tbh I've always found the ride comfort a lot better down at 20psi, Highest I ever go is 22psi if I'm going on a long journey and the Sj is loaded up.
