Post
by Darrell » Fri Jan 10, 2014 10:16 pm
dan_2k_uk wrote:That's unlike any 1.3 water rail I've seen before
I've not seen a cast alloy one either. Just a steel tube type.
timwilks13
- SCUK Website Padawan
Post
by timwilks13 » Fri Jan 10, 2014 10:35 pm
Luckily I had a spare 1.3 block kicking about! Didn't have a ring so use an old one with some PTFE tape, should hold and I'll silicone it up if need be.
- IMG_20140110_223249070.jpg (1.24 MiB) Viewed 3167 times
Hodgie812
Post
by Hodgie812 » Sun Jan 12, 2014 1:57 am
Aldi are selling O ring kits for £6.99, they have metric and imperial ones. Cheap enough and a available outside of normal motor factors hours. Handy as ....
Built with ebay!!!
Ladaman
- Suzuki Guru
Post
by Ladaman » Sun Jan 12, 2014 10:47 am
If you take your existing one with you and use it to compare the o ring section size. This is the important bit.
You can stretch a slightly small one to fit or shorten an oversize one by cutting with a sharp knife, then gluing the ends together with super glue.
