water rail removal
timwilks13
SCUK Website Padawan
water rail removal
Post by timwilks13 » Fri Jan 10, 2014 9:14 pm
Undone the bolt at the side of the water rail on the 1.6 block, and it spins round freely but wont come out, have I missed something?
Re: water rail removal
Post by dan_2k_uk » Fri Jan 10, 2014 9:15 pm
Strength?
Just pull it harder.
Ladaman
Post by Ladaman » Fri Jan 10, 2014 9:34 pm
Get Tramps Mrs round. She will give it a good pull.
Post by Darrell » Fri Jan 10, 2014 9:45 pm
But don't put it in the caravan or it will be proper f**ked :D
timwilks13
Post by timwilks13 » Fri Jan 10, 2014 9:54 pm
I used my friend MrPrybar, was covered in silicone though, is that cause for concern?
Post by Jordi » Fri Jan 10, 2014 9:57 pm
It will have been leaking. I got a new o ring from a local hydraulics place for free.
Post by Darrell » Fri Jan 10, 2014 9:58 pm
Nope, it's quite common to find silicon as well as the o-ring.
timwilks13
Post by timwilks13 » Fri Jan 10, 2014 10:10 pm
Excellent, got some spare rings at home, let's find one that fits!
Next issue, when I push the 413 rail in, it goes all the way in and the holes don't line up?
Post by dan_2k_uk » Fri Jan 10, 2014 10:13 pm
That's unlike any 1.3 water rail I've seen before
Post by Darrell » Fri Jan 10, 2014 10:15 pm
O-ring is an uncommon size that you won't find in your average assorted box
27.7mm ID X 3.5mm
There is an imperial size just a fraction larger.
