water rail removal
- timwilks13
- SCUK Website Padawan
water rail removal
Undone the bolt at the side of the water rail on the 1.6 block, and it spins round freely but wont come out, have I missed something?
Re: water rail removal
Strength?
Just pull it harder.
- Ladaman
- Suzuki Guru
Get Tramps Mrs round. She will give it a good pull.
But don't put it in the caravan or it will be proper f**ked
- timwilks13
I used my friend MrPrybar, was covered in silicone though, is that cause for concern?
It will have been leaking. I got a new o ring from a local hydraulics place for free.
Nope, it's quite common to find silicon as well as the o-ring.
- timwilks13
Excellent, got some spare rings at home, let's find one that fits!
Next issue, when I push the 413 rail in, it goes all the way in and the holes don't line up?
- IMG_20140110_220811247.jpg (886.03 KiB) Viewed 5665 times
That's unlike any 1.3 water rail I've seen before
O-ring is an uncommon size that you won't find in your average assorted box
27.7mm ID X 3.5mm
There is an imperial size just a fraction larger.
27.7mm ID X 3.5mm
