HELP i need a starter
lightning
Re: HELP i need a starter
Post by lightning » Mon Mar 07, 2011 9:06 am
ROBBIE wrote:is the engine in?
Yes m8
Post by ROBBIE » Mon Mar 07, 2011 9:17 am
dont think it can be ground down, dont think we could get the grinder in
have you tried difflock adds?
Post by ROBBIE » Mon Mar 07, 2011 9:31 am
just looked in the diff ads and theres nothing there ecept for people looking for starters
Post by twiss » Mon Mar 07, 2011 10:39 am
I'm gonna pull my starter off and see double check it's exactly the same as the one in my shed...
All of the bits off the valeo starters are interchangeable...
So if you grind/drill the rivets off, you can just bolt it straight together
lightning
Post by lightning » Mon Mar 07, 2011 11:04 am
twiss wrote:I'm gonna pull my starter off and see double check it's exactly the same as the one in my shed...
Thanks for your help
Will the starter that ferris part No M1T74583 fit 100% with out no grinding?dont want to get the wrong one again
just need a starter :bawling:
Post by ROBBIE » Mon Mar 07, 2011 1:33 pm
dont know if its the 1 you want http://cgi.ebay.co.uk/suzuki-sj-starter ... 2c5b0be29c" onclick="window.open(this.href);return false;
ferris
Post by ferris » Mon Mar 07, 2011 5:13 pm
I dont wan't to be responsable for you getting the wrong starter again. Heres a bit more info that might help. That part number is off the skinny starter im am using on my sj. I didn't buy it from new, i bought it from another member on here (parrot). He bought it from new, here is his post from difflock when he got it http://forum.difflock.com/viewtopic.php ... 78686098b1" onclick="window.open(this.href);return false;. If you did decide to order this one it might be best to get them to measure it for you befor they send it. The diameter of the skinny ones are 3" and the fat ones are 3 1/4". Hope this helps in some way, and good luck with the search. I know i had a nightmare trying to get hold of mine.
Also here is a couple of pictures of mine. Sorry the part number is a bit blurry in the pic.
ferris
Post by ferris » Mon Mar 07, 2011 5:54 pm
Just measured my old fat starter and it measures 3 1/4" not 4" like i said previously i just edited the above post to correct myself.
So just to confirm skinny starter 3"
Fat starter 3 1/4"
So only 1/4" differance between the 2.
lightning
Post by lightning » Tue Mar 08, 2011 7:14 am
ferris wrote:Just measured my old fat starter and it measures 3 1/4" not 4" like i said previously i just edited the above post to correct myself.
Fat starter 3 1/4"
Thanks for your help that looks like the one i want
Post by twiss » Tue Mar 08, 2011 9:41 am
Just so you know, there is someone on difflock who has a skinny starter and might not need it (philpy) ;)
Check out this thread on difflock
http://forum.difflock.com/viewtopic.php?t=61412" onclick="window.open(this.href);return false;
